Passenger window keeps shorting out. 01 sedan.
Old May 26, 2012
schizman221's Avatar
schizman221 is an unknown quantity at this point
Hi, the fuse for the passenger window keeps shorting out and I have no idea why it started doing this. When I bought the car it worked fine but then all of sudden it stopped. I bought a new motor for the window but it didn't fix the problem. I have looked for exposed/cut wiring but I can't seem to find anything. If any guru's out there have any tips or tricks to find the problem I would really appreciate it!
Old May 26, 2012
2009civic's Avatar
2009civic is an unknown quantity at this point
Re: Passenger window keeps shorting out. 01 sedan.
Is there water seeping in somewhere? Is your fusebox sealed down correctly?
Old May 26, 2012
I don't believe there is a leak. The fuse box under the steering wheel is where I found the blown 20A fuse for the passenger window. All of the other fuses seem to be fine except for that one. I have tried replacing the fuse a couple times, but as soon as the key is turned and the window switch is pressed the fuse blows. :/
Old May 26, 2012
lazlong's Avatar
Do you have a multi-meter and know how to use it?
Old May 27, 2012
04 Honda Civic's Avatar
Damn, I hate shorts. I wish I could be more help, but I am not too inclined when it comes to electrical problems.
I wonder if the switch itself can be shorting out the circuit. Have you pulled the door panel off already?
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Blazz
May 25, 2015 10:56 PM
timpan
May 18, 2015 07:06 AM
drhawkinz
May 16, 2015 11:39 AM
mwwhonda
Nov 7, 2001 07:24 PM
