Passenger window keeps shorting out. 01 sedan.
Hi, the fuse for the passenger window keeps shorting out and I have no idea why it started doing this. When I bought the car it worked fine but then all of sudden it stopped. I bought a new motor for the window but it didn't fix the problem. I have looked for exposed/cut wiring but I can't seem to find anything. If any guru's out there have any tips or tricks to find the problem I would really appreciate it!
Re: Passenger window keeps shorting out. 01 sedan.
I don't believe there is a leak. The fuse box under the steering wheel is where I found the blown 20A fuse for the passenger window. All of the other fuses seem to be fine except for that one. I have tried replacing the fuse a couple times, but as soon as the key is turned and the window switch is pressed the fuse blows. :/
Damn, I hate shorts. I wish I could be more help, but I am not too inclined when it comes to electrical problems.
I wonder if the switch itself can be shorting out the circuit. Have you pulled the door panel off already?
Blazz
May 25, 2015 10:56 PM
timpan
May 18, 2015 07:06 AM
drhawkinz
May 16, 2015 11:39 AM
