Headlight/Key left in Ignition Warning Beep Broken
Old May 14, 2012
jmon22's Avatar
jmon22 is an unknown quantity at this point
Have a little problem w/ my '03 Civic, as you see from the topic, my warning beep/alarm whatever you want to call it quit working. The Honda dealer wants $90 just to look at it which I obviously don't want to pay.
Anyone else have any idea what would be the next thing to look at? Thanks!!
Update and Cliffs:
-Dome light works fine when I open the door, it is not the door switch
-All of the fuses under the dash and under the hood checked out fine
-It does beep at me when I turn it on with no seatbelt on
-It will not beep when I leave the keys in the ignition or leave the lights on
Old May 14, 2012
Re: Headlight/Key left in Ignition Warning Beep Broken
make sure you check ALL the fuses under the hood and under the dash. if they are good, it could be parts of the multiplex unit (mcu) went bad. it is self correcting, so if one part breaks the other functions will still work. it could also be the beeper in the gauges died.
Old May 14, 2012
jmon22's Avatar
I checked all under the hood, I will check all under the dash tonight. If those are all good, does anyone know how to run the test to check the buzzer itself? I believe it tells you in the shop manual.
If I find out something is wrong with it, I believe it would just be easier to throw a new one in like this...
http://www.hondacivicwagon.com/bb/vi...p?f=10&t=13464
Old May 14, 2012
there is a gauge diagnostic mode but it only tests the needle motions, not the buzzer. if the buzzer beeps when you start the car with no seatbelt on, it is working okay. then the problem is with the multiplex unit.
Old May 14, 2012
jmon22's Avatar
Gotcha. I don't remember hearing the buzzer still working then either, but I will check when I get home. So if none of the sounds work the problem is with the buzzer? If so, is it easier to replace it or add a new one like in the link above?
Thanks a bunch!!
Old May 14, 2012
well if you can find a used gauge cluster on ebay with the same mileage, it would be easiest to swap another one in. otherwise yeah the diy buzzer you posted should work.
Old May 14, 2012
jmon22's Avatar
Fiance got home so I checked the car out. Here is what else I found:
-All of the fuses checked out fine
Is this for sure a problem with that part of the cluster that I cannot fix without replacing it? If so I will hit up Radio Shack tomorrow for a cheap Peizo buzzer.
Old May 15, 2012
seems the beeper is fine then (if it beeps for seatbelt). there is only one in the cluster. sounds more like mcu problem and in that case its way cheaper to do the diy. those multiplex units are not cheap.
Old May 15, 2012
pwnsauce's Avatar
pwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the rough
if that beeper stopped working in my car id cry. i hate that thing.
but i can see where it would suck if u left ur keys in ur car often.
Old May 15, 2012
jmon22's Avatar
My fiance already drained the battery once and had to call AAA.
Is there any chance this could of happened from an oil change and tire rotation I got done on the car on the 6th? I am not sure exactly when it started but it was definitely around that time. Could they have damaged the MCU somehow? Would love to go yell at them to fix it if I can.
Old May 15, 2012
CraigW's Avatar
Not related to recent service.
You could make a headlight on warning setup pretty easy with a visit to RS.
Won't help with key in ignition though.
Old Feb 18, 2013
drnet's Avatar
drnet is an unknown quantity at this point
My problem (dome light shutoff and headlight buzzer both inactive) involved a mispalced driver's door "switch" and easily solved by watching this video -
- woo hoo!
Old Feb 19, 2013
CraigW's Avatar
Pretty common, looks like the plunger/actuator fell out or stuck in.
Old Feb 19, 2013
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
Yes but OP says "-Dome light works fine when I open the door, it is not the door switch"
Old Feb 19, 2013
CraigW's Avatar
I think some CRV owners had similar situation that ended up needing the MICU replaced.
Old Feb 19, 2013
I see that old thread is old, and OP is probably long gone (Last Activity: 05-15-2012).
Since I almost never see DX cars, I'll ask: Are they even equipped with the headlight reminder?
Old Feb 20, 2013
@ezone, 6th gen DX, yes, constant on if key out and door open and headlights on. Not if headlights on, door open and ignition on. Not sure but don't think so if headlights on, door open, key in ignition but ignition off, then just short beeps (leaving key in the car - alarm)
So in summary (i'm half asleep) for 6th gen DX; 3 beep patterns; For seatbelts, key left in turned the off ignition and headlights on with door open with key out of ignition
Old Dec 8, 2014
tovarishch's Avatar
tovarishch is an unknown quantity at this point
Hello, I have exact same problem with my 2004 Civic.
Were you able to fix the problem?
Appreciate any help.
Old Feb 1, 2018
Naevulle's Avatar
Naevulle is an unknown quantity at this point
I know this is an old thread but I am having an issue with my 99 civic with the headlight warning buzzer, dome light, and driver side door. I have already replaced the driver side door jamb switch and the stuff still does not work. The dome light works fine with the passenger door. I do not have a buzzer that comes on for the seat belt, key or anything atm. Any ideas? Thanks.
Sep 26, 2023 06:44 PM
emich
Jul 20, 2015 08:42 AM
cukaracha
Jul 17, 2015 05:48 PM
