Shifter Light out
Old Apr 16, 2012
madonthemike's Avatar
madonthemike is an unknown quantity at this point
Shifter Light out
When I put my gear into D, the green light surrounding the D does not light up? But the lights in all the other positions work fine? How can I fix this?
Old Apr 16, 2012
Re: Shifter Light out
The wiring diagram shows them all to be LEDs. Each LED has its own resistor.
The parts catalog does not show any of the lights as separate.
P, R, and N are controlled by the trans range sensor.
D, D3, and 2 and controlled by the PCM.
May take a little investigating with a DVOM, and maybe a scanner.
If what I see in the diagrams is true, then if any of the LEDs are bad, you would be buying a new cluster if you can't solder in new LEDs.
HTH
Old Apr 22, 2012
HTH
Thanks ezone, but the light in the cluster, fixed itself - wierd one day doesnt light up at all and then its fine again.
Ma213802
May 18, 2015 07:01 AM
CiViCPrAnInG2k1
Dec 6, 2001 12:14 PM
01civicboi
Nov 23, 2001 03:02 PM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
StLVtec
Nov 14, 2001 09:22 PM
