Shifter Light out
Re: Shifter Light out
The wiring diagram shows them all to be LEDs. Each LED has its own resistor.
The parts catalog does not show any of the lights as separate.
P, R, and N are controlled by the trans range sensor.
D, D3, and 2 and controlled by the PCM.
May take a little investigating with a DVOM, and maybe a scanner.
If what I see in the diagrams is true, then if any of the LEDs are bad, you would be buying a new cluster if you can't solder in new LEDs.
HTH
HTH
HTH
HTH
Ma213802
May 18, 2015 07:01 AM
