shimmy and steering wheel wobble at 70+ mph
Old Mar 10, 2012
carfreak2300's Avatar
carfreak2300 is an unknown quantity at this point
hi there i just bought a 97 DX 5spd D16 and its been lowered and has a really bad shimmy and steering wheel shake at 70+ its driving me crazy and when the steering wheel is straight the wheels arent any thoughts bad alignment?
help
zeb
Old Mar 10, 2012
hawkijustin's Avatar
hawkijustin is an unknown quantity at this point
Re: shimmy and steering wheel wobble at 70+ mph
Could be bad tires, out of alignment or wheels need to be balanced. Check and see if the lugs are tight also. You could have broken lug bolts as well.
Old Mar 10, 2012
well im thinking that the alignment is needed to be fixed not sure yet going to get aligned soon will update asap
Old Mar 11, 2012
mac25's Avatar
Dr Krieger of Modification
are you one aftermarket rims?
they might be lug centric, meaning the wheel is bolted on and flush but it isn't exactley dead center or hub centric.
you can buy hub centric rings to fix the problem.
here's a link to more info. http://www.8thcivic.com/forums/wheel...ric-rings.html
Old Mar 19, 2012
Soo sorry for no update but after a few days of working on the dx i finally found my problem. stupid idiot i bought the car from wrecked it and covered up all the damage. but thats another issue all together. the struts were shot to **** because they cut the springs on stock struts. after updating those to coilovers i got new lower control arms in the rear because i needed them and theyre on their way now new control arm bushings done up front new cv axles as well as motor mounts and clutch. then i come to find out my power steering has been removed so i have some work ahead of me
Old Mar 19, 2012
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
Covering up information regarding an accident when selling a vehicle is illegal (depending on your state). I would definitely confront him about it. Sorry to hear about all that. If you're going through all that mess, why not find a used vtec d16 motor? They're like $200 tops. You'll be practically taking out the motor to replace the motor mounts, and the transmission to replace the clutch. Might as well toss that DX motor.
Old Mar 21, 2012
it turns out that the car did indeed not come with power steering but they swapped in a motor that had power steering on it -_- so that issue is fixed. but now i have a funky idle issue where when the vehicle is warmed up when i come to a stop the car will increase idle about 100rpms or so and when i start moving again itll drop any thoughts?
Old Mar 21, 2012
96DXSiR's Avatar
That's SiR to you!
96DXSiR is an unknown quantity at this point
Run some seafoam through it and clean your MAF.
Sorry to hear about the BS that guy gave you. I had a shimy in my DX when I first got it but it was just an alignment problem. I swapped in a B16a, and deleted the P/S. Unfortunately I paid for it in the end. It wore out the P/S Steering Rack and Pinion and I replaced it with a Manual NON Power Rack and Pinion. Works great now.
General 7th Gen
Jul 9, 2015 10:17 PM
CivicsClass101
Jul 9, 2015 11:14 AM
fvckbg
Jul 7, 2015 07:08 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
