High Idle
Old Feb 23, 2012
PaulforPOTUS's Avatar
PaulforPOTUS is an unknown quantity at this point
High Idle
I have a 96 civic dx which i just cleaned the IACV on. When i start the car and dont throttle or anything it idles nicely. But when i give it ANY gas it and let go the idle is stuck up at higher rpms. I have no tach so i cant say what #s for sure, but it is noticeably higher. I also noticed the engine maintains high rpm when i pop the clutch during a gear shift which kind of throws me into gear. Only upon stopping fully does it go back down. Any advice is appreciated
Old Feb 25, 2012
lazlong's Avatar
Re: High Idle
Throttle cable may need adjusting or replacement. Is the throttle plate rotating smoothly thru the entire range of movement? May also have blockage in one of the coolant lines going to the IACV.
Old Feb 26, 2012
Re: High Idle
thanks for the reply! i cleaned my tb of choke recently and just adjusted my throttle cable which, as you said,was a little off. But while i was cleaning my tb i noticed two small hairline cracks in the throat right where the butterfly valve meets when it closes. Big deal? not so much?
thanks
mistermenphis22
Jul 13, 2015 04:43 PM
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
671civicLX
Jul 4, 2015 04:02 PM
Bradel26
May 30, 2015 10:24 AM
1stcivic
Nov 18, 2001 09:17 PM
