Low beam problem
Low beam problem
Folks - I'm having a problem with the low beam headlights on my Civic. My car is an '03 EX sedan 5-sp manual. Today when I drove the car I noticed that the low beam weren't working (the high beams/flash to pass works properly). I looked at both headlight fuses under the hood and both appear to be good. Although there is space for 2 headlight relays, there's only one relay, which is in the relay #2 position.
I know it's possible that both low-beam filaments could've be burned out, but I just wanted to get some thoughs from some of you.
My plan is to swap out the headlight bulbs this evening.
Re: Low beam problem
I know I am possibly going the complicated route, but, Honda has a recall on our head light switch...apparently the head lights go out without warning...call them and ask...can't hurt
CarStuff
Dec 6, 2020 12:52 PM
intensity
May 12, 2015 10:43 PM
