Low beam problem
Old Jan 4, 2012
WayneJay's Avatar
WayneJay is an unknown quantity at this point
Low beam problem
Folks - I'm having a problem with the low beam headlights on my Civic. My car is an '03 EX sedan 5-sp manual. Today when I drove the car I noticed that the low beam weren't working (the high beams/flash to pass works properly). I looked at both headlight fuses under the hood and both appear to be good. Although there is space for 2 headlight relays, there's only one relay, which is in the relay #2 position.
I know it's possible that both low-beam filaments could've be burned out, but I just wanted to get some thoughs from some of you.
My plan is to swap out the headlight bulbs this evening.
Old Jan 4, 2012
CraigW's Avatar
Re: Low beam problem
Could be bulbs, post the results.
Old Jan 4, 2012
Some people will go to a lot of trouble to complicate simple stuff. I know I have.
Check the simple stuff first.
Old Jan 4, 2012
SpdySylvrEX's Avatar
SpdySylvrEX will become famous soon enough
I know I am possibly going the complicated route, but, Honda has a recall on our head light switch...apparently the head lights go out without warning...call them and ask...can't hurt
Old Jan 4, 2012
Oh yeah, DUH!
Problem: The USA recall is on 01-02, not 03 Civic.
Doesn't mean it couldn't still be a problem though. CRVs do it too and they aren't part of the recall.
Old Jan 5, 2012
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
I would just replace the bulbs, if that doesnt work then take it to honda..
Old Jan 5, 2012
If you're gonna replace, go with the sylvania 9006 (don't quote me on the number)? I believe, Advance has them for $45.
They are the nice bright ones
CarStuff
Dec 6, 2020 12:52 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
intensity
May 12, 2015 10:43 PM
Hondasport01
Lighting
Jul 12, 2005 07:45 AM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
