Tightening up loose steering
Old Dec 19, 2011
user 987458's Avatar
user 987458 is an unknown quantity at this point
I have a 1998 Civic LX with 210,000 miles on it.
The steering, compared to other cars I drive (often newer rental cars), feels comparatively loose and I was wondering what kind of repair/maintenance I'm in for before I take it to the shop.
By loose, I mean I can shimmy the steering wheel back and forth without feeling like it's going to change my course at most speeds. Making turns is no problem, but when I'm at high speeds, I often feel the responsiveness and traction is not there.
Is it just the Civic design with slim wheels or could it be something else?
Old Dec 19, 2011
MindBomber's Avatar
Live for the Twisties
Re: Tightening up loose steering
Worn tie rod ends and ball joints can have a significant impact on steering responsiveness, you can easily check them yourself by jacking up the car and seeing how much play the wheels has.
The parts are relatively affordable, under $60 for OEM and under $50 for off brands, between one and four hours worth of labour depending on exactly what needs to be replaced. Changing only the tie rods will be much less work than ball joints if they are also worn.
Old Dec 19, 2011
Thanks for the feedback. I'll jack it up and test that out then take it to my shop.
Thanks again!
Old Dec 20, 2011
At 210k anything is possible.
I'd like to add:
If the suspension checks out, look at the tires. Many tires have a "mushy" response feeling due to construction, materials, and sidewall flex. Cheap tires are bad about it. At what point did you notice the condition again?
I recently put a set of (I think) G/Y Eagle GT tires on a stock Prelude. The owner was back in under an hour complaining of crappy handling. It was the tires. Some people notice that stuff, some don't.
Tire inflation plays a big part too. Low tires don't respond.
Sway bars and struts: The car can't make the turn until the body is done rocking.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
alaga
25
Aug 13, 2015 04:42 PM
17
Jul 23, 2015 11:48 PM
califcamper
Jul 21, 2015 10:34 PM
CivicsClass101
Jul 9, 2015 11:14 AM
