How do you get those two screws for the head unit?
Old Nov 10, 2011
Shortys123's Avatar
Shortys123 is an unknown quantity at this point
The two screws above the 12V socket that need to come out appear to be 8MM but my socket slides off them, and a screw driver starts to strip them. They are lock nuts i think.
Old Nov 10, 2011
MindBomber's Avatar
Live for the Twisties
Re: How do you get those two screws for the head unit?
They're 8mm iirc, if the socket is sliding off then try a 6mm.
Don't put them back in when you re-install everything, I tossed mine and have had no problems.
Old Nov 10, 2011
rjones7755's Avatar
Theyre defiantly 8mm (I had to take them off today). And the only reason i put them back in is to make it a little harder on thieves to steal my headunit haha.
Old Nov 10, 2011
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
yea, those little screws are retarded and they strip so easily. Also it's easy to over torque them and break them off.
Old Nov 10, 2011
04 Honda Civic's Avatar
Any time you have a choice between a screwdriver and a socket go for the socket.
A little tip is to take the socket and put up on the ratchet as you unscrew them. Its a weird position but try to push up as your unscrewing it helps.
Old Nov 10, 2011
raigen18's Avatar
raigen18 is on a distinguished road
o those two screws caused me a lot of grief... took me forever to take apart the centre console just to get those screws the first time i installed my aftermarket deck. fast forward a few months, i needed to remove my deck so i went through all the work of taking out the centre console only to realize i never ended up putting those two screws the last time i installed the deck! man did i feel stupid
Old Nov 10, 2011
yeah, having the whole dash torn apart is much better than having them pull out just the center piece that you can replace on ebay for $20.
Old Nov 11, 2011
MonKy's Avatar
MonKy is an unknown quantity at this point
when i had my hu installed the installer didn't put the screws back in.. so now i can grab the hu housing n rip it out
Old Nov 12, 2011
lazlong's Avatar
Yeah, nobody re-uses them. They're pretty much all like that.
Old Nov 12, 2011
Shortys123's Avatar
Still haven't gotten them off. An 8mm slips off the nut so to say. The nut appears to have little notches on it, some sort of safety nut. They really didn't want anyone to steal the radio.
Old Nov 12, 2011
MindBomber's Avatar
Have you tried vice grips, kind of a weird angle, not sure if they'd fit..
Old Nov 13, 2011
Shortys123's Avatar
What the heck are the nuts even securing? You can reach your finger around the bracket and touch the threads. I can't get the nuts off I'm literly drilling right through the nuts. You wont be able to see the mess in the end anyway.
Old Nov 13, 2011
Shortys123's Avatar
Got it in finally
4 banger
Jun 5, 2015 01:44 AM
rawtalent14
Jan 22, 2002 09:29 AM
bobbyd
Jan 7, 2002 01:31 PM
Slow2k1Civic
Jan 1, 2002 06:51 PM
noodles01
Dec 28, 2001 09:07 AM
