How do you get those two screws for the head unit?
Rep Power: 0 How do you get those two screws for the head unit?
The two screws above the 12V socket that need to come out appear to be 8MM but my socket slides off them, and a screw driver starts to strip them. They are lock nuts i think.
Live for the Twisties
Rep Power: 261 Re: How do you get those two screws for the head unit?
They're 8mm iirc, if the socket is sliding off then try a 6mm.
Don't put them back in when you re-install everything, I tossed mine and have had no problems.
Theyre defiantly 8mm (I had to take them off today). And the only reason i put them back in is to make it a little harder on thieves to steal my headunit haha.
Rep Power: 229 Re: How do you get those two screws for the head unit?
Any time you have a choice between a screwdriver and a socket go for the socket.
A little tip is to take the socket and put up on the ratchet as you unscrew them. Its a weird position but try to push up as your unscrewing it helps.
o those two screws caused me a lot of grief... took me forever to take apart the centre console just to get those screws the first time i installed my aftermarket deck. fast forward a few months, i needed to remove my deck so i went through all the work of taking out the centre console only to realize i never ended up putting those two screws the last time i installed the deck! man did i feel stupid
Rep Power: 788 Re: How do you get those two screws for the head unit?
yeah, having the whole dash torn apart is much better than having them pull out just the center piece that you can replace on ebay for $20.
when i had my hu installed the installer didn't put the screws back in.. so now i can grab the hu housing n rip it out
Rep Power: 0 Re: How do you get those two screws for the head unit?
Still haven't gotten them off. An 8mm slips off the nut so to say. The nut appears to have little notches on it, some sort of safety nut. They really didn't want anyone to steal the radio.
What the heck are the nuts even securing? You can reach your finger around the bracket and touch the threads. I can't get the nuts off I'm literly drilling right through the nuts. You wont be able to see the mess in the end anyway.
4 banger
06-05-2015 01:44 AM
