omni 70mm throttle body
I got a 70mm omni throttle body, and ported out the intake manny to match on the inlet.
My first qustion is at the bottom of the stock t.b there is a sensor that is not able to transfer to the omni 70mm t.b-- what is the fix?
Second, may be related to first, got a check engine light on after running fine first few runs...Then a little different shifting,power,low idle???
I understand tuning, and more for more....In time.
Please chime in and give me any help you can ...
Thankyou!!!
Thankyou!!!
Re: omni 70mm throttle body
Thanks!
um, aftermarket throttle bodies do not work well. i had all sorts of problems with just a stock tb that was ported a few mm bigger. the tps was never reading right and i always got a cel. this was with all the stock sensors on it too. with an auto trans, this makes the car barely driveable and unable to shift when it should. the problem is even if you somehow calibrate the tps sensor, there are other sensors that will get affected later on and the ecu will throw codes. they are expecting a certain air volume and speed.
Problem solved! This port and throttle body give a noticable increase in acceleration, not boost but I'm pleased. I had a small vacuum leak. I have videos and such I will post.
Sorry you had no luck with the idle, my 99 civic idled down low but I adjusted the throttle cable and shes perfect with better gas mileage and a quicker step!
Thank ya'll!
Thank ya'll!
Bruce2
Sep 27, 2015 08:45 PM
Bricoleur
Sep 9, 2015 12:30 PM
