HELP!manual trans wont shift left or right, stuck in nu,3,4 gear
I just did a trans swap for a guy with a 2001 civic with a 1.6 vtec. His told me the old trans made alot of bearing noise and was hard to shift in to 3-5+ reverse. (just back ground story) I started tearing her out and right away I noticed the motor and trans was covered in oil. This made a fairly clean swap very dirty. When I got the trans out I noticed that the trans housing was cracked on the front side. That is why all the oil is everywhere, and why the bearings where noisy and hard to shift. Well I put in the trans he brought with ( a rebuild he bought off someone). I went to drive it and I live on a country road so I drove up into 1,2,3,4 gears and when I went to down shift I couldnt move the shifter to the left into the 1st and 2nd gear bank or to the right 5th and reverse bank. I ended up driving the car back to my house in 3rd and 4th only. It goes into 3rd and 4th great just wont move side to side. When I got back I popped the hood and had a friend try shifting it and it seems the "#9 lever comp, shift" (referring to the link attached) doesnt move up and down like it should. I puller the shifter cables off and tried to pull and push the "lever comp" but it didnt budge. I searched and searched and cant seem to find anything that helped me. Can I just pull it out and swap it with the one from the old trans? Please any info will help. Thank you anyone in advance.
http://www.hondaoriginalparts.com/ho...block_03=13120
Re: HELP!manual trans wont shift left or right, stuck in nu,3,4 gear
Then maybe you should go back to the DSM forums? Just because we don't answer a post immediately doesn't mean we're being jerks. We have lives and the most helpful members on here post every day or every other day. You could have a linkage issue. But a rebuild may be in order.
I am not putting anyone down. It was just at that time I have 58 people to have viewed my post and not one reply. The trans is suppose to be a fresh rebuild. It has been opened recently since there is fresh rtv on the case seems.
Flipg123
May 8, 2015 01:15 PM
oneheadlight
Apr 29, 2015 11:30 PM
davidpaustin
Apr 29, 2015 02:23 PM
Russps
Nov 8, 2001 02:00 AM
