2002 Right Brake Light Out
Re: 2002 Right Brake Light Out
Double check the bulb, inspect the socket.
Tough to say where junction would be right off hand.
You could tie into the problem side with a new section of jumper wire. (Brake = WHT/BLK) If you did not already know.
And then... run it across the back and tie into the wht/blk on the working side. Or go forward with new jumper and do the same tapping into the high mount wiring.
I suggest soldering connections made.
CarStuff
Dec 6, 2020 12:52 PM
Civic2002lx
Oct 7, 2015 09:17 AM
izdman
May 19, 2015 03:43 PM
Ma213802
May 18, 2015 07:01 AM
