rear drum to disc brake conversion DIY?
Old Oct 1, 2011
99dxneverstress's Avatar
southern cali cruising
99dxneverstress is an unknown quantity at this point
Question rear drum to disc brake conversion DIY?
anyone know of one? or any tips searched around through the threads didnt find anything.
Old Oct 3, 2011
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
Re: rear drum to disc brake conversion DIY?
boilermaker made one for the 7th gens. it's very similar to the 6th gens and the thread is there for you to ask your questions and get the help and guidance you need.
link: https://www.civicforums.com/forums/4...elled-out.html
Old Oct 3, 2011
much appreciated bro i'll take a look
Old Oct 10, 2011
redhulksmash's Avatar
redhulksmash is an unknown quantity at this point
There is a company called Scarebird that makes a bracket to do the disc conversion without swapping the control arms
then I went with rear brake components off of a 99-00 Si
need:
scarebird bracket
calipers
caliper bracket
pads
rotors
brakes hoses
e brake cables
proportioning block ( not completely needed, brakes will still favor the front though)
new spindle nuts
You could also go with brake setup off an integra or other 6th gen civic with disc brakes
Old Oct 10, 2011
CanadianCivic02's Avatar
CanadianCivic02 is an unknown quantity at this point
Do it properly and take your time, if bolts break buy oem bolts from honda not some hardware store. I see too many people locally doing this swap and having break failure while driving.
Rear disk FTW!
Old Oct 11, 2011
Zeferint's Avatar
Autocross Padawan
control arms...? I think you mean trailing arms? Also, without replacing the proportioning valve, the brakes will actually favor the rear because more pressure is required to squeeze the drums than the calipers. More rear brake bias can be very dangerous, and it's best if you get a 40/40 prop valve.
sbi
20
Oct 23, 2015 01:34 PM
rtachs
Jul 16, 2015 05:32 PM
Optimus34
May 25, 2015 11:52 PM
rhvic
May 22, 2015 03:06 PM
Broadbeb
May 14, 2015 09:49 PM
