Need Turbo Help! Got Questions 98 Civic Si
Old Sep 28, 2011
npstr's Avatar
npstr is an unknown quantity at this point
I am looking to turbo my 1998 Honda Civic Si Coupe with a D16Y8 engine. I have a few questions. Like why some turbo kits will not work with A/C and Power Steering and others will? Also what are the advantages of turbo vs a swap? as well as the parts list I would need to ensure my build goes smoothly.
P.S. I will be hopefully rebuilding the engine a bit to ensure it can take the turbo without blowing the engine!
If you have any comments or anything like that, please post! Would love some feedback and advice.
Thanks
Old Sep 28, 2011
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
Re: Need Turbo Help! Got Questions 98 Civic Si
The A/C and P/S take up an astronomical amount of room in your engine bay, so to make a turbo fit you need piping that's able to work around it. It's not that the turbo won't work, it just won't fit. A B-swap will run you about the same amount of money that it would cost to boost your D, but the turbo would yield you much better power results. Head work isn't required but recommended if you plan on running 10psi+. While you got the head off I'd take the block out and freshen it up. New rings, bearings, possibly hone the cylinders. I'd look at spending around $3500.
Old Sep 28, 2011
MatthaiN's Avatar
MatthaiN is an unknown quantity at this point
What happened to the B-Series motor that should have been in that 98 SI already??
Old Sep 28, 2011
npstr's Avatar
It is the Canadian Si, therefore, came with a standard D16Y8 That is why it is not a B series. The B series came in the US model and also the D16Y8 is SOHC VTEC the B series from the US is DOHC VTEC
Old Sep 29, 2011
MatthaiN's Avatar
Ok, Makes sense now. I was confused because my 97' EX had the D16Y8 stock.
Old Oct 2, 2011
npstr's Avatar
Still looking for more help and ideas, even comments or suggestions
Old Oct 2, 2011
MatthaiN's Avatar
It may not be from our gen of civics, but there is a lot of good info in these threads.
https://www.civicforums.com/forums/7...turbo-faq.html
Old Oct 3, 2011
Zeferint's Avatar
Autocross Padawan
What are your goals for the car? Autox? DD? what about power wise?...would help us help you.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
dano2005
Apr 14, 2015 01:58 AM
colombianDXcivic
Bolt-on Engine Performance
Nov 8, 2001 12:14 AM
supraman
Nov 6, 2001 05:50 PM
HitlistCivic01
Oct 27, 2001 07:47 PM
