1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Loosing faith in Mechanics - Honda Civic 1993 issues!
Old Sep 23, 2011
honvic's Avatar
honvic is an unknown quantity at this point
I have had 2 different diagnosis from 2 different mechanics for issues of black smoke and high idling with my Honda Civic 93, DB15 engine with twin carby, manual, AC.
I have lost my faith in mechanics and I would like to know opinions on what I should do. Should I fix it myself??? I have already replaced the fan switch, O2 sensor and have had a major service done.
The car blows black smoke, even after a major service. Once warmed up, it would idle at 1800-2100 and the black smoke usually disappears. The black smoke is due to a fuel and air mixture issue which results in my car only getting 300-340klms per full tank, than before where it use to get 480-550klms per full tank. I presume this is due to the high idle and fuel mixture/black smoke issue.
It struggles to stay idle at less than 1600rpm, so when I first start the car in the morning, I would have to drive it around till it gets warmed up otherwise it dies or otherwise, I have to rev the car when at a stop at about 1800rpm for it to remain running.
1st Mechanic diagnosis-
sticky choke
valves need adjusting to fix black smoke
2nd Mechanic
Carby requires overhauling
Choke/Wax pellet not working
Power vale fault(I presume its a mistype and should say valve)
Vacuum leak from carby intake rubbers
I tend to believe the 2nd mechanic since they were recommended by a close friend who has been going to the same mechanic for over 10 years.
Are the faults listed from the 2nd mechanic DIY'able? Would I be better off buying a used twin carby or engine? What are my possible options because I have spent almost 4K on this car on repairs alone and I have only had it for a few years!! Now I have to spend more!!! I could have spent for a later model car at the start if I had known this car would have had so much issues!
Any help, opinions or advice appreciated.
Old Sep 23, 2011
Re: Loosing faith in Mechanics - Honda Civic 1993 issues!
valves?!?
2nd one, please...
what major services? they might have messed something while doing it.
do you have experience with carburetors? they just need adjusting unless the newer additional alchohol is eating away the carbs...
PS: black smoke is usually oil, white is fuel...
miatabro
Jul 17, 2015 12:12 PM
Civicman92296
Apr 23, 2015 09:22 PM
jessicakaybby
Apr 20, 2015 12:11 PM
dooner24
Apr 14, 2015 07:51 PM
gabrown2
Apr 11, 2015 08:22 PM
