97 civic wont start
Old Sep 10, 2011
gibson171's Avatar
gibson171 is an unknown quantity at this point
97 civic wont start
my 97 civic d16y8 wont start when at operating temp. its starts n runs fine until u turn off, then it wont start until it cools down. ive replaced the coil, igniter, plugs, wires, cap, rotor, fuel filter, even the main relay. there are no codes on the ecu. im out of ideas.....
Old Sep 10, 2011
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
Re: 97 civic wont start
This could either be really simple... or really bad. Does the car at least turn over or does nothing happen when you turn the key? Can you push start it?
Old Sep 11, 2011
gibson171's Avatar
its starts and runs just fine until the key is turned off, then it has to cool down to restart, but it does turn over, ive checked for fire and am getting spark while its doing this, its automatic so i cant push start
Old Sep 11, 2011
Zeferint's Avatar
Autocross Padawan
First I'd get your alternator and battery tested. If those come out fine check your fuel pump sensor, if not that then check the fuel pump itself. If the car is turning but not starting then there's spark but no fuel.
Old Sep 12, 2011
gibson171's Avatar
fuel pump working just fine
Old Sep 12, 2011
Zeferint's Avatar
Autocross Padawan
Ok, then certainly get your alternator and battery tested. If not, I did a simple google search "Car won't start when hot" and got about 1489107824012 search results.. first 6 results:
http://sg.answers.yahoo.com/question...3105859AA46Pla
http://www.car-forums.com/s9/t3615.html
http://ls1tech.com/forums/general-ma...-hot-help.html
http://www.car-forums.com/s9/t13361.html
http://www.rx8club.com/showthread.php?t=155305
http://www.audiforums.com/forum/gene...tart-hot-8842/
Old Sep 12, 2011
Zeferint's Avatar
Autocross Padawan
edit..accidental double post
Old Sep 12, 2011
haao13's Avatar
haao13 is an unknown quantity at this point
try the coolant temp sensor
Old Sep 16, 2011
gibson171's Avatar
ect sensor was the problem
CarStuff
Dec 6, 2020 12:52 PM
smmahan
Apr 15, 2015 08:17 PM
SSMatey
Apr 13, 2015 06:09 PM
gabrown2
Apr 11, 2015 08:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
