plastic strut bearing to replace metal?
Old Sep 6, 2011
vdub's Avatar
vdub is an unknown quantity at this point
I just redid my struts and am going to get it aligned but it sounds like I'm not suppose to have the plastic bearing mounts? I have a 02 civic ex coupe. It had metal bearings on it but the ones I ordered that came were plastic so I put them on. Should I change them or will they work?
Old Sep 6, 2011
MindBomber's Avatar
Live for the Twisties
Re: plastic strut bearing to replace metal?
The 01 bearings are plastic and they break and start popping quickly, you want the metal ones.
Old Sep 6, 2011
sl33pyriceboi's Avatar
if u order a replacement, u should get the meatal ones because honda doesnt carry the plastic ones anymore. it has been updated to metal
Old Sep 7, 2011
lowlife9's Avatar
i recently purchased 01oem plastic upper strut bearings from majestic.
Old Sep 7, 2011
Speed9117's Avatar
Speed9117 will become famous soon enough
Yeah I went to my local Honda dealer last fall and they didn't know what I was talking about when I asked for metal bearings.... I just got the plastic ones for my 01
Old Sep 7, 2011
ask for the 2002 bearings. that might help.
some dealerships still have the old plastic ones for the "2001" still in stock
Old Sep 12, 2011
bigheadmark's Avatar
bigheadmark is an unknown quantity at this point
my front end makes a slight clunk noise when i turn the steering wheel..also, the front struts make a clunk noise ...ALL the time..
I checked the plastic donut bearing, and both sides are intact...
can these plastic donut bearings make noise if they are NOT broken??
I heard about indexing, but the top mount will only go in 1 way into the 3 holes..
and yes, i have done a boat load of research on this site...I can't seem to figure out why they are clunking
Old May 15, 2012
zXeX's Avatar
zXeX is an unknown quantity at this point
Does anyone know if the 2000 Civic can suffer from this same issue? I have a thump/pop that occurs every so often but can't track it down. All ball joints are good, axles are fine, just replaced all motor mounts and both wheel bearings. The clunk/pop usually happens after the 1st start up of the day and with the 1st turning of the wheel as the car is in motion. Then after that, it is just random. Sometimes while driving on a rougher road, you can hear a rattle.. Sounds kinda of like when the motor mounts were bad... just not as loud.
Old May 17, 2012
mikereynolds9's Avatar
mikereynolds9 is an unknown quantity at this point
Idk if it's just my area but when I was ordering parts fr my car I called several different dealerships so I can get the plastic bearings for my progress suspension. Every dealership said they had plenty in stock.
Old May 18, 2012
jsut upgrade to the 03+ strut bearing/hat.
they are far better than the 01-02 design.
Old May 21, 2012
Thaik's Avatar
Thaik will become famous soon enoughThaik will become famous soon enough
When you guys say "plastic bearing", are you talking about the actual ball bearings or the strut mount itself that where the bearings is mounted into. Because I can hardly imagine plastic ball bearings holding up against all that stress.
I intend on replacing my bearings but I don't know if I should replace the entire strut mount assembly or the bearings only, are they easy to replace?
Thanks
usajags84
15
Aug 19, 2015 03:12 AM
edgenet
May 2, 2015 08:00 PM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
bluecoupe
Dec 19, 2001 10:08 PM
