Bearing squeek from power steering pump?
I changed my drive belts about 4 moths ago (timing, power steering, alternator). About a week later I started to hear a squealing noise occasionally, I wrote it off as just the new belts breaking in and it did seem to go away for a little while. It came back about 4 weeks ago much worse. When I turn the car on I hear a very high pitched, rather loud squealing for about 5 minutes and then it goes away. It doesn’t happen ever time and seems most prevalent when the car has been sitting for a long time (particularly in the hot sun). It sounds a lot like a bearing failing. I checked the belts for damage, dirt or excessive play and didn’t find any and recently added belt conditioner. I used a screwdriver as a stethoscope to ‘listen’ to some of the bearings. I can’t say I’m an expert in what to listen for and none of the times I checked was it making the noise but the power steering pump seemed ‘off’, kind of a grinding/humming, definitely louder then the alternator or anywhere else I checked. I’m thinking it might be the bearings on the power steering pump but I don’t get the noise when I’m turning, only when I turn the car on which makes me think the alternator is more likely but it sounded fine as far as I could tell with my limited experience. Is it plausible this could be a bearing on the power steering belt despite the fact it doesn’t seem to be related to turning or wheel position at all? Any other suggestions are welcome as well.
moorebl
Aug 29, 2015 08:39 PM
vvr210
May 31, 2015 08:02 PM
