window fuse keeps blowing
Old Jul 19, 2011
pasadenaed's Avatar
pasadenaed is an unknown quantity at this point
Hello everyone. This is my first post to this forum. I've had this problem for about 2 weeks now. I've searched various forums and looked for an answer on the web but haven't found anything that targets my problem.
Well I own a 2002 Civic ex that keeps blowing a fuse as soon as I turn the key to the ON position. The fuse controls the front passenger power window. It's a 20 amp fuse, #23 I believe. I thought it might have been the motor that went bad and was drawing too much current so I replaced the motor with a new one and it still blew the fuse. I disconnected the terminals going to the window motor as well as the window switch on the passenger door just to eliminate those as potential problems. Well with those terminal disconnected, I replaced the fuse, turned the key to the ON position and the fuse blew instantly, without me even touching the window switch on the driver's door.
I looked to see if I could see any wires that were pinched or exposed, but i couldn't see any. Any ideas what I should check next? Is it possible that the fuse box itself has gone bad just in that one fuse slot?
Old Jul 19, 2011
Kennykid2002's Avatar
Kenny the Ricer
Re: window fuse keeps blowing
Sounds like a short, meaning you have a power wire touching the wrong thing.
Don't know where it could be though. It most likely is within the wiring to the pass window
Or there might be a short behind the fusebox
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
1khilari
Jul 9, 2015 08:12 PM
ZILLA
Jul 5, 2015 05:24 PM
Ma213802
May 18, 2015 07:01 AM
