Pulling my hair out over this someone help!
Old Jun 11, 2011
talon187's Avatar
talon187 is an unknown quantity at this point
Ok i have a 2003 honda civic 2 door dx 1.7 i bought car with 102000 on it. since ive owned i changed timing belt all seals and idlers. plugs. tire/wheels front breaks. ign lock cyclinder rebuilt new battery. heres my issue. car had a altenator and battery form autozone when i started driving battery would not hold a charge. i changed it. I then noticed afer letting the car sit for the weekend battery was dead. So i went and had altenator checked couldnt check it if i unpluged the connector to the altenator it would be able to test it. I then put in a denso. same thing happened. after a few days. I then called the dealer and they told me mitsubishi was the oem alteantor and they have seen issues with after market ones before. I then got a mitsu. Same thing. So i then bought an oem from the dealer same thing. im stumped what could cause this anyone know have any ideas? I checked all my fues pulled one at a time and test and also tested with volt meter everything was in check thing was wrong or seemed wrong. could the ecu do this? also when i called the dealer they said there was a sensor or somthing in the fuese box but when it went bad it would cause a check engine light. if anyone could give me some help it would be great thanks
Old Jun 11, 2011
MelJ's Avatar
Trance Addict
Re: Pulling my hair out over this someone help!
You might have a parasitic drain somewhere in the car if the battery is dead if it's been sitting for such a short period of time.
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=141&t ransactionid=1307834996-6724824270&posted_by=MelJ_www.civicforums.com&yout ube_video_id=jTECmj78ZOU[/autostream]
Old Jun 11, 2011
talon187's Avatar
nice vid but like i stated before i checked all that and it tested fine. i just dont get how the altenator could draw current when the connector is pluged in and the car is off. iknow for the conenctor its got 4 wires one goes to the ecu one must be power one is ground and can someone tell me what the last one is for? and where exactly they run to ?
Old Jun 11, 2011
lazlong's Avatar
Take it down to Autozone and have them scan it for codes (it's free). If you get P1298 then you need to replace the Electrical Load Detector(ELD) in the under-hood fusebox. Part #38255-S5A-003. Use the specific part number 'cause if you go to the dealer and ask for the ELD they will try to sell you the entire fusebox ($250).
Or troubleshoot the alternator and regulator circuit with the service manual (it will also tell you what wire is what): https://www.civicforums.com/forums/1...e-updated.html
Old Jun 11, 2011
talon187's Avatar
whats the ELD do? when i talked to the dealer they told me that was replaceable and like $30 and i dont have a check engine light on....
Old Jun 12, 2011
lazlong's Avatar
It's a power regulator. My light wasn't on but, I still had a P1298 for the ELD. Light doesn't have to be on to be storing a code. Bad ELD wouldn't cause a battery drain though.
Old Jun 12, 2011
talon187's Avatar
Blah im very anonyed i noticed that ELD is connected to some of the wires in the altantor and i noticted there is also a realy for the alteantor be hind the glove box any idea how to tell witch relay it is? i just dont get what could kick on this damm thing someone said its possible ecu was doing it. so i dissconnected it and rehooked up the battery and no change....
Old Jun 13, 2011
floyd107's Avatar
floyd107 is on a distinguished road
your batt can be dying if you have a amp hooked up wrong? or something in that type of field. your old batt just might of seemed like it wasent holding a charge because its older and dies quicker.and the newer one will just take longer.if you dont have a amp just look around for something that might not be shuting off. check and see if any wires are running off your batt that might not be conected to something right.last but not least chances are slim but see if your hood may be touching in any way i once had a car that did the same thing and it was my hood touching the batt term.
Old Jun 13, 2011
lazlong's Avatar
Speaking of which: watch out, the connector for the ELD can be plugged into 2 different spots, only 1 of which is the right one.
I kept getting the ELD code and had it plugged in wrong.
Old Jun 13, 2011
floyd107's Avatar
yep its the stupit stuff like that,and you will prob over look that everytime until it finally hits you. and hopefully thats before you drop you baby off at the doctors and hand you machanic free money.
Old Jul 2, 2011
talon187's Avatar
Still havent figured this out lol. i even bought a oem altenator from honda. i had a friend check it out and its drawing 1.3 volts form the top right pin on the connector of the altentor somthing is kicking it on when it should be off i havent figured out what yet
Old Jul 3, 2011
lewi103's Avatar
lewi103 is an unknown quantity at this point
Goodmorning dude hey here is something you can try i just finished fixing my dads car same problem.ok if you have a 12volt probe tester with the ignition off and key out disconect the negative battery cable and connect the clip to the negative cable and the probe end to the negative pole if the light on the probe turns on that means something is drawing power so now what i want you to do is start pulling fuses untill the light goes out when it goes out check what ever is connected to that fuse.another thing if you have an after market alarm disconnect that too.in my fathers car 2000 civic the alarm was the problem.and also to test your altenator with the car running disconnect the - cable from battery and turn everything on wipers radio ac lights exc if the car stays running then that means alternator is good try this and let me know good luck dude.
SimpleUser
Apr 24, 2021 02:54 AM
mrohitredd
Aug 12, 2015 11:36 AM
loosescrew84
16
Aug 11, 2015 07:08 PM
tattedlariat
Aug 4, 2015 06:35 PM
beeemerdude
Jul 23, 2015 03:53 PM
