Reloacted Alarm Speaker, Car won't start?!?!?!?!
Old Apr 27, 2002
Pir8pete
Guest
Posts: n/a
So I wanted to relocat my alarm speaker. So I disconnected it, the alarm was off the car turned off, just parked in my driveway, but I left my battery connected. I unrapped were the splice was near the speaker and reran the two wires to where I wanted my alarm speaker to be, and the wires touched, but I didn't think that it mattered cuz everything is off right? so I continued and had to start my car to move it and put it on jacks, hummmmmmmm?????? it won't start it just clicks, all my assories are working but the starter won't turn [IMG]i/expressions/face-icon-small-mad.gif[/IMG] [IMG]i/expressions/face-icon-small-mad.gif[/IMG]
I have a clifford Arrow 3 basic install
any help would be great
ps. I have checked all my fuse boxes under the stearing wheel and also under the hood but they all seem ok??????
Old Apr 27, 2002
01SOHCcivic's Avatar
01SOHCcivic is an unknown quantity at this point
read your manual
i had the same problem with my compustar
all you gotta do is reset the whole system and it will start working again
BTW
this should be in tech
Old Apr 27, 2002
ROBREALZCIVIC's Avatar
ROBREALZCIVIC is an unknown quantity at this point
If two wires touched then the ignition fuse might have blew, check all your fuses!!!
Old Apr 28, 2002
KevinFWB's Avatar
KevinFWB is an unknown quantity at this point
Its possible that you blew a fuse on your alarm as well. Who installed you alarm, hopefully they werent dumb enough but.... When you hook up your starter kill, you hook up the starter wire to the nc (Normally closed) contacts on the relay. Which means that the starter wire works as normal if something should happen to the alarm. I have seen some people wire it to the NO (normally open) contacts, when means the relay has to have power in order for the 2 sides of the starter wire to have contact. The problem with that is if something happens your ignition kill relay goes from close to open and then you have no juice going to your starter. CHECK YOUR ALARM FUSES since that's what you were messing with.
Old Apr 28, 2002
supsoop's Avatar
supsoop is an unknown quantity at this point
unplug the battery for 3 mins and replug it, then try to turn on the car again, i had something similar happen
Old Apr 28, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
didnt i just respond to this in vehicle issues/problems dont cross-post
Old Apr 29, 2002
Pir8pete
Guest
Posts: n/a
you did just see this msg in another form but a mod moved it in here [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
thank guys i figured it out, i blew the 5v fuse inline on my alarm [IMG]i/expressions/moon.gif[/IMG]
mistermenphis22
Apr 3, 2016 08:06 AM
Linda0818
Apr 23, 2015 11:30 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
