Need help on headlight ES1
i need help on my headlight cause i need to do brake n light inspection.well my 01 civic got into a crash and i convert the front to 04-05 civic front end.and i wanna if the low beam and headlight suppose to switch off when i switch them from low or high beam or do all of them suppose to stay on.i met a guy with the same car and all his light stay on without switching so i wanna know if mines suppose to switch or not as you can see on the picture.any suggestions will help thanks.
Re: Need help on headlight ES1
when the high beams are on (meaning the blue indicator is on, on the dashboard), then both bulbs should be on.
the highbeams are another filament in the bulb that's on in the 2nd picture
DRL's are the other filament in the 2nd picture.
Normal night time lights are exactly what your first picture is: outside bulb on and inside bulb off
For the 01-03 when the lowbeam is low beAm is on, the hight beam is off. When the high beam is on? The low beam is off. (unlike the 04-05)
What you need to fix this is a Proper hid relay.
yeah normally the 04-05 headlights keep the lo beam on when the hi beam is used. but since you are starting with 01-03 car and wiring for h4 bulb, the hi beam turns off the lo beam. you need to make a new relay harness for the lo beams and run the hi beams off the stock wiring. if youre not good with electrical and wire diagrams, i would leave it as is. the way you have it wired now will still pass inspection no problem. many cars with separate lo and hi turns off the lo beam in hi beam mode too.
ahhh i forgot he mentioned he did a front end conversion. what i said should still be what it would look like on an 04-05.
you can use the diagram i made for my hid lo beams relay harness. instead of the d2s ballasts in the pic, substitute the 9006 lo beam halogen bulbs. wire the hi beams the same way as in the diagram to the stock wiring as indicated. this is for 01-03 civic so the wire colors are correct.
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
