Need help with chassis wiring in rubber conduit to driver door 1996 Cicic EX
Old Apr 18, 2011
kee68's Avatar
kee68 is an unknown quantity at this point
Can anyone explain how to repair bare wires going into door from fuse panel on a 1996 4 door Civic? when I peel back the rubber boot there is a green connector with about 20 or so wires going into it. Is that a plug that can be unpluged? I have no power windows or locks due to issues in that connector. I bought the car that way used. Any help would be greatly appreciated. I am new to this Forum so if I am posting wrong let me know.
Old Apr 18, 2011
CraigW's Avatar
Re: Need help with chassis wiring in rubber conduit to driver door 1996 Cicic EX
Can you see the open end of the rubber grommet/tube carrying the wires to the door ??
If you gently tug on the wires (1 at a time) are any broken and pull out of the tube easily ??
If you could determine which wires are broken... you can splice a new section in and run them back into the door and splice into the other end of the break inside the door (matching wire color codes)
mohawkboom
67
Aug 25, 2015 12:28 AM
maaronia
May 14, 2015 10:46 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
supercivic01
South
Nov 30, 2001 11:27 AM
