Specific Lights out when changing headunit?
Old Apr 6, 2011
stewartfan's Avatar
stewartfan is an unknown quantity at this point
Last Saturday, I believe, I took off the panel by the shifter just to make sure that it would be doable for me to perform the H/U exchange on my car. After putting everything back on, I noticed that the lights (PRND,etc) were out. I hit the shifter a couple times just to see the lights come on for a second, and then turn back off, never to turn back on again. Personally, I think it's almost distracting when I'm driving since I'm used to it being there. It can also become a nuisance when I am shifting at night, as I always look down when I shift. Today, I got the headunit and installed it. Upon putting the dash back together, the lights on the bottom **** (Fan speed) was really dim, as if one of those lights had gone out. So far, that light has been working well since. Out of all of these, though, the one that bugs me the most is that the symbols on the buttons below the H/U (A/C Rear Defrost, Recirc) don't light up anymore. They still control everything correctly and the indicator LEDs still work, you just can't see which one is which at night. Otherwise, the other lights work perfectly, minu the buttons and shifter lights.
Any help is appreciated!
Thanks!
Old Apr 6, 2011
CraigW's Avatar
Re: Specific Lights out when changing headunit?
Shifter = #74 bulb
HVAC= assorted neo-wedge bulbs
In your case I would replace them all.
Old Apr 6, 2011
stewartfan's Avatar
Ok, where do you suggest I purchase those? Should they be at my local Honda dealer? And are they substantially more expensive there? I just need white lights, right?
Old Apr 6, 2011
lollygagger's Avatar
Person
lollygagger has a spectacular aura aboutlollygagger has a spectacular aura about
http://www.hondaautomotiveparts.com/...artsSearch.jsp
Put in your year and model. For the climate control unit bulbs, the system you want is the Heater Control, part number 1 or 12 depending on which you need. For the shifter, the system field you should choose is Select Lever, and the part number to light up the panel is 1.
Old Apr 6, 2011
electric130's Avatar
Did you connect the "illumination" wire on the head unit?
Old Apr 6, 2011
Person
lol yeah check that first
Old Apr 6, 2011
CraigW's Avatar
The #74 can be purchased at auto parts store or at dealer, the neo-wedge at the dealer $3-$5 each.
Old Apr 6, 2011
stewartfan's Avatar
No, I did not. It's just certain lights, not all of them.
Old Apr 6, 2011
that's the typical symptoms of connecting the illumination wires on an aftermarket HU. particularly the HVAC lighting. some lights are out, but not all of them.
Old Apr 6, 2011
Person
My console lights were killed when I replaced my HU and my friends shifter lights were killed when he did his.
Old Apr 6, 2011
stewartfan's Avatar
Were you guys able to fix them or no?
Ok, well there was no orange cord that came from the stereo's harness, so there's no way it got hooked up. Nothing's wrong with the HVAC *****.
Old Apr 6, 2011
Person
Oh yeah we just replaced the bulbs....easy fix.
Old Dec 2, 2011
stewartfan's Avatar
I know I'm resurrecting this thread, but I finally replaced the lights in my console and I want to share my experiences. I shopped around online and ended up just going to my local Honda dealer because every one I looked at. the quality seemed little iffy, or the shipping was way too expensive, or you had to buy in bulk. I replaced all 5 of the bulbs (Gear selector (1x), HVAC buttons (2x), HVAC ***** (2x)) even though the ones on the ***** weren't completely dead yet. It ended up being just $15 for all 5, and they didn't have them in stock but they got them to me the next day. Not too bad if you ask me. I attached before and after pictures; take a look!
ID:	82166   Click image for larger version
Old Dec 4, 2011
r3fuj33's Avatar
r3fuj33 is an unknown quantity at this point
Did you notice if they got any brighter after the swap? Mine seem like they're getting pretty dim.
Old Dec 4, 2011
CraigW's Avatar
The bulbs can get a black buildup inside over time.
I did all 5 at once on my 05 and they looked great afterwards.
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
Supramk3
May 11, 2015 07:55 PM
tylerginevan
Apr 27, 2015 12:29 PM
2k1TypeR
Sep 25, 2001 09:25 AM
