RPM Goes High but Car Does not Move
Hello everyone, I need your help please. I have a 97 Honda Civic EX Vtec Engine D16Y8. I just swapped out the engine, changed the Spark Plugs, Wires, Axles, Battery, Distributor O-Ring, and Vtec Solenoild Gasket, then the car run a little wierd like the RPM goes up to 3000 or 4000 but the car just moves very slow every time I stopped at the Stop sign, Traffic Light, or parking and star moving the car. But after that, it runs excellence. So What is the problem with it? what should I do?
Re: RPM Goes High but Car Does not Move
are u using the ecu that came with the new motor.
if ur prev engine is the same engine then ecu is not the culprit
but if u have a diffrent motor from prev and used that ecu on the new motor it wont run right
i had bad experience with auto trannies
so u r using ur old tranny i suppose
somtimes it could be the tourqe converter
my prev auto tranny die 3 times when i had my camry v6
it would rev up from a dead stop and rise up slowly
then when it gets to about 40 it start moving as normal
then later on it stop moving at all
burnt auto tranny
burnt auto tranny
Sounds like a torque converter or bad clutch? Probably need a new tranny u could always try tranny repair fluids i had an issue once with an auto tranny i used lucas and it worke mint after
burnt auto tranny
burnt auto tranny
I just flashed the Transmition Fluid and put the new one in there. I didn't use lucas but I used the regular ones. Just in case, if the problem is the Tourqe Converter, then do I need to replace it or is there any way I can fix it?
for manual trannies its the clutch that have contact
auto is torque converter
did the motor came with the engine or did u take out the tranny
cuz somtime when not putting in the torque converter correct it can caused problems http://www.hondaautomotiveparts.com/...RQUE+CONVERTER
bottom picture figure 6
http://www.hondaautomotiveparts.com/...ry5=AUTO+RADIO i thought this was funny
factory radio cost 400 bucks
wtf
wtf
torque converter is the piece that connect the motor to the tranny
im sorrie dont take my word for it
i never take auto tranny off from a motor before
but from wat my dad said that the torque converter does play a role on auto trannies
u should bring it to somone to get better diagnose to know the exact problem
it could be even a bad transmission too
i did some research
http://www.ehow.com/about_5039041_sy...converter.html
this should help u better understand ur symptoms
i did some research
yeah keep me posted cuz i wanna know the out come too
wtf
wtf
and thanks for the rep
Pr0n1s
Apr 30, 2015 03:08 PM
cooldan1
Apr 23, 2015 10:49 AM
McD
Apr 16, 2015 10:46 AM
dooner24
Apr 14, 2015 07:51 PM
