clutch
Old Feb 12, 2011
xXDaILyCiVIcXx's Avatar
xXDaILyCiVIcXx is an unknown quantity at this point
clutch
i have a 2003 honda civic ex coupe, 1.7l sohc motor
ok. i am having the problem of my clutch pedal is very stiff or hard to press, and when the car is running i can not get the car to go into gear at all.
i can start the car in a gear though and it will automatically start taking off from a dead stop.
i can move thru the gears fine when the car is not running as well.
Old Feb 12, 2011
brobo's Avatar
brobo will become famous soon enoughbrobo will become famous soon enough
Re: clutch
HOW MANY miles and do you do burnouts and other ways to torture car
Old Feb 12, 2011
Re: clutch
138k and no its just my daily driver, never dropped the clutch or raced the **** out of it, it just started doing it to me yesterday at random.
Old Feb 12, 2011
Re: clutch
Try a tranny fluid drain and fill. See if that helps at all.
Could be a number of problems otherwise: synchros, bearings, etc..
Old Feb 13, 2011
Re: clutch
thats what i was gonna do. i was just seeing if i could get some more ideas on here.
any ideas on what would make it sound like its just spinning, like if i am driving and i am slowing down and push the clutch in, almost like its not engaging kinda thing, it just sounds like the clutch or a bearing is just spinning around inside
Old Mar 11, 2011
Re: clutch
so i found out what it was. it had a daikon clutch in it and it was a dual spring, well one set of springs was completely gone and then one was starting to break. put a act street performance clutch and Pres plate in it, new throw out bearing, and its good ot go now.
but what would cause the springs to just break like that?
Old Mar 11, 2011
Re: clutch
RU the first owner? bad clutch habits could do that
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
powman02
Sep 15, 2015 07:38 PM
Klame9420
Sep 7, 2015 10:03 PM
