Fuel Maxx/ Battery/ Radio
Ok, so my sons 99 EX that he just bought has a Fuel Maxx attatched to it. A guy I work with who knows a little more about Civics suggested i remove it and then disconnect the batter for about 15 minutes re reset the ECU, but warned that the radio will not work after that. I read the post that said to call Honda etc. to get reregiostered to my name and get a code. Is there any way to make the radio display the code before I disconnect the battery or is it really necessary to disconnect the battery after removing the fuel maxx? Thanks, Pat
Re: Fuel Maxx/ Battery/ Radio
just a warning, ive never been able to get codes for the pre-2001 civics. so try not to erase it. there should be an ecu fuse you can pull out which is like disconnecting the battery. i highly doubt you need to reset the ecu just for a fuel max lol. it doesnt do anything. and even if it does, the ecu relearns on its own anyway.
lol, what some ppl will buy, o god that made me laugh. They come out with these gimmicks every few years just like that tornado insert for the air intakes what a joke. Anyhow that said no you do not need to disconnect the battery to remove that useless piece of junk. If you ever want to reset the ecu there is a ecu fuse that you can pull and keep power to the radio, in addition removing that fuse for 30 seconds will reset the ecu for you.
Kinneybrk
Jul 24, 2015 02:41 PM
Dave1984
Jul 22, 2015 06:10 PM
