Fuel Maxx/ Battery/ Radio
Old Feb 8, 2011
brooksman9's Avatar
brooksman9 is an unknown quantity at this point
Ok, so my sons 99 EX that he just bought has a Fuel Maxx attatched to it. A guy I work with who knows a little more about Civics suggested i remove it and then disconnect the batter for about 15 minutes re reset the ECU, but warned that the radio will not work after that. I read the post that said to call Honda etc. to get reregiostered to my name and get a code. Is there any way to make the radio display the code before I disconnect the battery or is it really necessary to disconnect the battery after removing the fuel maxx? Thanks, Pat
Old Feb 8, 2011
Re: Fuel Maxx/ Battery/ Radio
just a warning, ive never been able to get codes for the pre-2001 civics. so try not to erase it. there should be an ecu fuse you can pull out which is like disconnecting the battery. i highly doubt you need to reset the ecu just for a fuel max lol. it doesnt do anything. and even if it does, the ecu relearns on its own anyway.
Old Feb 9, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
lol, what some ppl will buy, o god that made me laugh. They come out with these gimmicks every few years just like that tornado insert for the air intakes what a joke. Anyhow that said no you do not need to disconnect the battery to remove that useless piece of junk. If you ever want to reset the ecu there is a ecu fuse that you can pull and keep power to the radio, in addition removing that fuse for 30 seconds will reset the ecu for you.
Old Feb 9, 2011
brooksman9's Avatar
Thanks. Where is the ECU fuse?
Old Feb 10, 2011
Newfiedan's Avatar
the backup fuse under the hood 7.5amp fuse you will see it on the label for the fuse cover.
Old Feb 10, 2011
brooksman9's Avatar
Thanks. If I can ever catch that boy at home long enough I will take care of this.
Kinneybrk
Jul 24, 2015 02:41 PM
Dave1984
Jul 22, 2015 06:10 PM
jody501
Jul 10, 2015 11:01 AM
magog45
Jul 9, 2015 06:23 PM
