high pitch squealing when car starts??
hey when i start my car i get a high pitched squeal, so im guessing this is one of my belts.. my friend told me to water each one down until i see which one is making the noise, any suggestions? thanks
Re: high pitch squealing when car starts??
High pitch squeal is generally caused by a loose or worn out belt. It's either the accessory belt or the power steering belt. Depending on how many miles you have on them just get them replaced, if they are fairly new it's probably the result of an improper install and just tighten them up. The accessory belt and p/s belt on these cars dont have an auto tensioner so they won't keep tension as they wear.
If your going to put anything on the belts don't use water use belt dressing. It works way better.
My car makes the same noise. But i have changed both of my belts and it still does it mainly when i start my car. i have been told that I have a baring that is going out in one of my pulleys. Anyone have a idea of the main one that I need to start with on checking?
thanks in advance.
thanks in advance.
mikemc422
Aug 9, 2018 05:41 PM
dragonsblood
Apr 27, 2015 12:28 PM
Blaster30
Apr 22, 2015 12:21 PM
tattedlariat
Apr 12, 2015 07:55 PM
