VTEC Problem
Old Jan 20, 2011
xxslayerodxx's Avatar
xxslayerodxx
xxslayerodxx is an unknown quantity at this point
VTEC Problem
Alright I gotta 2004 civic ex. A code popped up P2646 (VTECH OIL PRESSURE SWITCH CIRCUIT LOW VOLTAGE). So I read some forums and changed out the solenoid with a new one. The whole solenoid part came with a new oil switch too. The check engine went off, I drove it around and the light came back on and its the same code. I don't know what to do next.
Old Jan 20, 2011
Re: Vtech Problem
check oil lvels. v-tech is oil pressure activated, and if you level is low, it will not work and throw codes - sorry, but that was the least expensive action you could have taken before trying sensors...
Old Jan 20, 2011
xxslayerodxx
Re: Vtech Problem
Yea man I checked the oil level just got an oil change I checked the levels and it was good
Old Jan 20, 2011
Re: Vtech Problem
?!? let me take a look on something
Old Jan 20, 2011
xxslayerodxx
Re: Vtech Problem
Alright
Old Jan 20, 2011
Re: Vtech Problem
filter under the VTEC solenoid?
http://www.crvownersclub.com/forums/...ad.php?t=13338
Not the VSA system, but the filter is mentioned in the civics also (they have same engine, mostly
Old Jan 20, 2011
xxslayerodxx
Re: Vtech Problem
If your talking about the screen on the solenoid I checked it out and I didn't find no blockage you think it could be the ecu be a problem?
Old Jan 20, 2011
Re: Vtech Problem
i am at a loss, unles the oil passages are clogged somehow.
Mine were an oil leak, so low oil level. the manuals cite the solenoid, oil switch, the filters, beyond that, just to check for normal checks, like for wiring, oil conditions, etc.
Ah, there was some notes for spool valve in the solenoid
let's see if someone else butts in that have had this issue
Old Jan 20, 2011
Re: VTEC Problem
if the screen is clean and oil is full, its prolly the vtec oil pressure sensor. lol, i just noticed thats what your engine code is for. yeah its the sensor. you can get it separately i think instead of buying the whole thing.
Old Jan 20, 2011
Re: VTEC Problem
if the the new switch was bad, that is.
but maybe the wiring?
Old Jan 20, 2011
xxslayerodxx
Re: VTEC Problem
Yea it's funny though because I bought the solenoid piece and it came with new oil sensor then hen code came up again I bought a new switch from autozone cost me 89 dollars had to special order and it still reads p2646
Old Jan 20, 2011
Re: VTEC Problem
autozone switch? i wouldnt really recommend aftermarket parts for important stuff like switches and sensors. you might have an ecu problem then.
Old Jan 20, 2011
xxslayerodxx
Re: VTEC Problem
That was my next step to check the ecu but I was hoping it wouldn't be a big part
Old Jan 20, 2011
Re: VTEC Problem
g'luck...
Old Jan 20, 2011
xxslayerodxx
Re: VTEC Problem
Thanks
Old Jan 21, 2011
xxslayerodxx
Question Re: VTEC Problem
Would any of you guys know how to reset my ECU?
Old Jan 21, 2011
Re: VTEC Problem
with the car off, pull the FI ECU fuse and put it back in
Old Jan 21, 2011
xxslayerodxx
Re: VTEC Problem
I would think reseting my ECU would do the trick but still have the problem
thana
Jun 15, 2020 07:05 PM
tadr88
Jun 8, 2015 12:28 AM
01civyv3
Jun 2, 2015 05:21 AM
LionSpratt
Apr 26, 2015 01:02 PM
Tybonater
Apr 24, 2015 07:03 PM
