Timing Belt Freak of nature!
Old Dec 31, 2010
warz1's Avatar
warz1 is an unknown quantity at this point
I have a 2001 honda civic ex..It has 75k miles
Here in Ny we got a big snow storm and i park my car at my job,was away working for a few days..
I went to start my car and i could barely heard anything..I popped my hood and found out that the entire engine was packed with snow. I pushed it in the shop and hooked a space heater up and let it all defrost..
The starter spins and all the belts but no compression, sounds like an electric car lol..I'm guessing it has to be the timing belt but was wondering if maybe the tensioner got stuck or something?. Do you think i could have bent a valve on a half dead battery trying to start it? I wasn't going 50 miles per hour, just tried to crank it over quick. This is just a freak of an accident that happened, i never heard of this happening before
Any advice would be appreciated..I don't mind doing the timing belt, just hope the valves weren't bent Thanks
Old Jan 1, 2011
Warzbird's Avatar
Warzbird is an unknown quantity at this point
Re: Timing Belt Freak of nature!
Any suggestions? This is my daily driver car and i just cant see the timing belt snapping due to this Thankss
Old Jan 1, 2011
TRIZ's Avatar
First, whats with two different usernames??
Second... Its unclear what really happened... do you have pictures of the engine bay before thawing it and do you have video of the startup??
Old Jan 1, 2011
warz1's Avatar
Sorry, i thought i was a member of this forum before and signed back up(since forgot user name didn't work)
No, i didn't take pictures..Starter spins but it wont turn over(has never since this problem)..I remember in the summer i added some water to my coolant.. Maybe the water pump froze or the fuel lines? Alternator belt turns..
I rarely drive this car, because it sits at the shop and we are always out of state in company vehicles
Thanks for your time!
Old Jan 1, 2011
MindBomber's Avatar
Live for the Twisties
Its not unusual for belts to be completely knocked off if you attempt to start a car after the engine bay has been packed by heavy snow. If the belt wasn't knocked off when you go it to the shop, then my suspicion would be that slipped and put your timing off. Timing off, potentially bent valves.
Old Jan 1, 2011
warz1's Avatar
I'm going to say it didn't slip, because wouldn't there be some type of compression?
Old Jan 1, 2011
MindBomber's Avatar
You could completely lose compression if the valves were bent badly enough, I'm fairly confident this is the issue, because its a common problem in areas with routine heavy blowing snow.
Old Jan 2, 2011
BlueEM2's Avatar
Whachya lookin at?
What I can see happening is the water pump being frozen in place and the crank spinning the timing belt around it chewing up all the grooves out of the timing belt as you attempt to crank it. I've actually seen it happen on an old sunbird where the coolant was all frozen. So if you tried to crank it for a few minutes youve caused enough damage to the belt for it not to function any more.
Old Jan 2, 2011
warz1's Avatar
Would the Cam sensor make it not turn over?
Old Jan 3, 2011
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
No.
But a bad cam sensor will not let the engine start.
Is the CEL on?
Old Jan 3, 2011
MindBomber's Avatar
Yes, but I doubt thats the problem, because a snow storm couldn't foul the cam position censor.
Do you have any more information you can give us?
Old Jan 3, 2011
BlueEM2's Avatar
Whachya lookin at?
By frozen do you mean the coolant was frozen? Or do you mean there was snow in the engine bay?
Old Jan 3, 2011
warz1's Avatar
there was snow in the engine bay.. Ive been on the road and getting back now.. Im going to take the timing cover off and make sure its on and the points line up..Hoping its someone besides that thoooo
Old Jan 3, 2011
warz1's Avatar
I took the timing cover off..Belt is fine, Just no compression.. It did make a "puut putt" sound at first, but nothing.. What now? Thanks
Old Jan 3, 2011
MindBomber's Avatar
Did you check the timing?
Old Jan 3, 2011
warz1's Avatar
Nope..Just towed it out the shop and going to have my a shop look at it..Damn snow caused to many problems!
mattdoc
Mar 14, 2017 12:10 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
dano2005
Apr 14, 2015 01:58 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
