1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Need help with Front end Vibration 91 civic Hb DX
Old Dec 9, 2010
IloveMyHonda's Avatar
IloveMyHonda is an unknown quantity at this point
Unhappy Need help with Front end Vibration 91 civic Hb DX
Any one know what is causing it?
The car vibrates very badly when ill first start it up, then once its warmed up it doesnt do it as bad. The while im driving it seems to smooth out,
And there is also another Problem, When i am Shifting it it makes a strange Revving noise, But them it almost sounds like a grinding..
Old Dec 9, 2010
89civichatch's Avatar
89civichatch is an unknown quantity at this point
Re: Need help with Front end Vibration 91 civic Hb DX
sounds like ur throw out bearing,when they get wore out they will cause the car to vibrate at idle,and will also make the clutch grind....good luck man
Old Dec 17, 2010
MartinL's Avatar
MartinL will become famous soon enoughMartinL will become famous soon enough
I was doing some research for the same problem I have on my 91 civic. The most logical thing I think it is are the motor mounts. They are old and have probably worn out. On hot summer days when I park the car whilst I work, I come back to the lot and the car does not want to shift out of first or second gear (auto transmission). After 20 minutes of driving around it eventually works. Told this could be a transmission solenoid.
TomSchaeffer
Nov 2, 2021 07:31 AM
bsmiley
Apr 27, 2015 01:27 PM
GH04si
Apr 15, 2015 08:13 PM
streetglower123
Apr 12, 2015 10:56 AM
