2005 ex stuck in park and won't start??
Old Oct 13, 2010
collbreezejr's Avatar
collbreezejr is an unknown quantity at this point
New to forum guys!
My 2005 Civic EX is stuck in park and will not start. It does crank over. The immobilizer light is not on, and the brake lgiht work. My girl parked it the other night and then in the morning it would not start. All fuses check ok. Any ideas???
Old Oct 14, 2010
lazlong's Avatar
Re: 2005 ex stuck in park and won't start??
Probably your transmission range switch, #18: http://www.bkhondaparts.com/billkay/...itch=&hidIrno=
Old Oct 14, 2010
Kennykid2002's Avatar
Kenny the Ricer
Are you stepping on the brake?
Sorry, kinda obvious, but some people space out sometimes, then they go "DOH!"
Old Oct 14, 2010
lazlong's Avatar
I call shenanigans. You only have to step on the brake pedal to change gears. The OP said it cranked, if your not it P or N it won't even crank.
Old Oct 14, 2010
CraigW's Avatar
On the 7th gens system you SHOULD be seeing the green imobilizer light flashing (just not rapid flash)
Old Oct 14, 2010
Kenny the Ricer
that's what i meant, he OP said "its stuck on park"
so im assuming that he cant change gears
Old Oct 18, 2010
aspork42's Avatar
aspork42 is an unknown quantity at this point
make sure that the battery isn't dead. I left the dome light on one night and killed the battery. Without that, the gear selector won't move... (just in case you forgot to mention that your g/f left the lights on)
SSMatey
Apr 13, 2015 06:09 PM
gabrown2
Apr 11, 2015 08:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
black2k1vtec
Dec 6, 2001 09:49 PM
