96 Civic 1.6L turns over but won't start
Old Jul 24, 2010
HillBillyJoe's Avatar
HillBillyJoe is an unknown quantity at this point
Question 96 Civic 1.6L turns over but won't start
I have a 1996 Honda Civic LX standard 1.6L 4cyl 5 speed 108K. It was starting fine with no problems, however it did have a little bit of a rough idle. I then took it to the car wash to degrease the engine compartment. After spraying it down the car started and ran for about 20 seconds as I was driving away it shut off. I had to get it towed home. So I went to the parts store and bought new plugs, wires, and cap. Still just turns and turns will not fire up. Any sugestions? Rotor? Coil? Distributor? Timing belt? I walked to the gas station and added a gallon of gas to the tank, that was the first thing I tried. I went to the local parts store and rented a OBD II scanner. It came back with NO error codes. The rotor does turn when cranking.
Old Sep 25, 2010
mazbo1's Avatar
mazbo1 is an unknown quantity at this point
Re: 96 Civic 1.6L turns over but won't start
I have the same problem and I need some answers myself
Old Sep 25, 2010
OK well I got it running. Check all your plugs, wires, cap, and rotor. Then I replaced the ignition coil and it works fine now. It's about $80.00 or so.
Old Sep 26, 2010
mazbo1's Avatar
Cool ! I also searched and saw that the Coolant Temp Sensor could cause the car not to start? Is this correct?
Old Sep 27, 2010
No, I have never heard of coolant Temp Sensor causing a car not to start. You can always invest in a Haynes or Chilton manual, they give you step by step trouble shooting guides. Tell me more about your problem? So I can understand what's happening.
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
jackoncruzpr
Apr 16, 2015 12:29 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
