AC/Idle issue in 01' civic
Old Jul 21, 2010
Jenni's Avatar
Jenni is an unknown quantity at this point
SO....
Current symptoms:
I live in AZ. Mornings are 90-ish degrees. Afternoons are 110+.
No symptoms at all when AC is not turned on (air can be blowing, but AC button will not be active). Morning commute there is no issue or symptoms. Afternoon commute, when driving with AC on, car drives fine for approx. 5 minutes, air blows cold and idle is normal. After 5 minutes, the cars AC blows warm, and the cars' idle jumps from below 1k up to 2.5k rpm's. Again, after 5 mins, the car returns to normal, cold AC good idle, and repeats this cycle. (When the symptoms occur, the air that is blowing feels more humid, if that helps.)
Here's what's been done so far:
Week 1:
Put in new AC compressor (old one had a missing clutch).
Had "shop-in-corner" recharge the system.
Tightened AC/Alternator belt
Week 2:
Topped off freon until gauge indicated it was at higher level of "good".
Replaced battery (old one had dead cell anyway)
Week 3:
Replaced AC/Alt belt
Removed oil-caked air filter
Tested Valve cover breather hose as symptoms occurred, no changes
Looked over rest of engine as symptoms occurred; belts moving fine, radiator fans going, no unusual vibrations, etc.
At one point my car had a really weird idle during all of this, and the check engine light came on. The code was P0505, which indicated "Idle Control System Malfunction." SO.... where should I start looking now? Cuz everything I have had the know-how for, I have done.
UPDATE: (7/27/10)
My car runs normal when it's no more than 105 degrees.... so wtf!? Is it seriously gonna only do this when it's so ridiculously hot that it's the only time I wish the ac would actually work fine? No fix?
Old Jul 21, 2010
Jenni's Avatar
Re: AC/Idle issue in 01' civic
I also just now checked the AC Condenser fan fuse, and it was ok. I though, I have not been able to properly locate the AC Condenser fan that everyone mentions looking at in other threads....
Old Jul 21, 2010
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
The condenser fan is same place as radiator fan, the condensor fan is smaller, if both turn it is ok.
Old Jul 21, 2010
Jenni's Avatar
So you're referring to the two fans that sit on the one side of the radiator? (The space between the radiator and the engine itself)
Old Jul 27, 2010
Jenni's Avatar
update.... please read and provide possible input.
Old Jul 27, 2010
Yes, there are two fans on the radiator. I think the condensor fan is on the left (if sitting in driver seat) on yours.
Old Jul 27, 2010
Jenni's Avatar
ok... well both are working when this occurs... so that may not be the issue =C
Old Jul 28, 2010
lazlong's Avatar
Did you do the idle re-learn? You have to do this after you work on just about anything on this car. Is the car overheating?
Old Jul 29, 2010
Jenni's Avatar
my only response to that first part of your post
I know my car is not overheating. the therm needle is at normal temp and does not fluctuate when the car is having its issues. Otherwise... unless it's 106 and over, there is no problem. even if it's 110, but my ac is off.... there is no problem. just happens with ac on and ambient temp at 106 and up. =C
Old Jul 29, 2010
lazlong's Avatar
"..." =C
Idle Re-learn:
1. Make sure all electrical items are off.
2. Start the engine,and hold it at 3,000rpm without load (park or neutral) until the radiator fan comes on, or until the engine coolant reaches 194F (normally operating temp).
3. Let the engine idle for about 5 minutes with the throttle fully closed.
NOTE: If the radiator fan comes on, do not include it's running time in the 5 minutes.
- The hotter it gets the harder the A/C has to work. Could be something else in the A/C system like the evaporator, evaporator temp sensor, or receiver/dryer.The moist air is also making me think it might be a headgasket. Sometimes that's a symptom. Just for piece-of-mind I'd check for a blown headgasket.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
civic_gt
Apr 19, 2015 08:15 AM
Streetlife
Nov 8, 2001 05:31 PM
skywalker
Nov 8, 2001 05:04 PM
