1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Buying a 94 Civic ex
Old Jul 10, 2010
Civictim's Avatar
Civictim is an unknown quantity at this point
I'm new to civics, but am buying a friends 94 ex. He says the cat is backed up. When cold, it idles and runs fine, but once up to operating temp, and you cut it off, it will not start. It tries to start, but sounds as if it's "loading up", and will try to idle at abut 4 or 500 rpm, but when you give it gas, it dies. When the car cools off, it will start and run normally... Does this sound like the cat, or something else? No cel's are on. I'm gonna buy the car regardless of what the problem is, I'd just like to know what direction to go with this problem. Car has 145k, and has been maintained well.
Old Jul 14, 2010
jworth's Avatar
jworth is an unknown quantity at this point
Re: Buying a 94 Civic ex
Doesn't sound like the cat to me. My boy's 93 had a rattle coming from his. 1/2 of the honeycomb was broken into bits. On his, there are disks of honeycomb. At least there were. I just took off his and hanked out the broken pieces and the mesh "gasket" that seals the honeycomb against the walls of the cat. His had no running issues at all.
Anyway, I don't think it's the cat. It'd be easy enough to find out though. Just bust up the honeycomb in the cat. If you have to pass smog inspection, that cat won't do it for you anyway.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Jonnie.
Jan 13, 2019 11:21 AM
bsmiley
Apr 27, 2015 01:27 PM
cheekyvirgin
Bluetooth
Apr 27, 2015 05:31 AM
LionSpratt
Apr 26, 2015 01:02 PM
