Upstream O2 replacement
OK, I feel like an idiot having to ask this but here goes.
Background:
MIL came on, brought to get the code read, comes back with the upstream o2, ok, cool.
Break out my Haynes manual and realize that I have a VTEC engine and the manual only has pictures of non-VTEC.
Hopefully someone can answer this for me;
Looking straight down, past the radiator, there is what looks to be (going by the length of the wire bundle) the o2 sensor, is that the upstream?
04 Civic EX, engine D17A2, if that helps any.
Background:
Re: Upstream O2 replacement
jack the car up. It's easier to reach from there. Your upstream O2 sensor is located near the 90° bend of the downpipe.
Since it's going in on the horizontal, more or less anyway, I can use a regular open-end wrench, yes?
I used an open ended wrench when I swapped mine out. Like ^^ mentioned, they do make O2 sensor sockets
yeah it's easy to get off. you can use an open end wrench or socket as stated. You could also try turning the motor on and allow it to warm up and then trying to wrench it off. This should only be if it's hard to get off.
Wouldn't a hot sensor be harder to take off? Heating different metals expand at different rates so the threads are REALLY tight against each other... just sayin..
Thanks for the info guys! I should be getting it sometime next week, had to order online. Which brings up another question.
I ordered a Bosch but they're subbing me a Denso, they both seem to have the same specs, is one better than the other?
I noticed the retail price of the Denso was way higher but that doesn't always mean much.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
JetsterDajet
52
May 8, 2016 12:11 AM
michael0219
Sep 1, 2015 10:25 PM
USCGBM
Aug 12, 2015 04:22 PM
