d17a2 exhaust back pressure? cat delete...
Old Jun 19, 2010
tom1987tm's Avatar
tom1987tm should not be trusted
im planning on getting an aftermarket header and downpipe from ebay for cheap and also doing a cat delete. i have a cat back exhaust of off a friends car that will work.
my question is will i actually loose power due to not enough back pressure? ive heard that the engine needs the pressure.... im not sure.
also by doing a cat delete i head that the car will have an undesirable raspy sound. is this true? and how can i change the sound. the cat back exhaust is 2.5 in tubing. fyi.
any thoughts would help....
Old Jun 19, 2010
02civicsi02's Avatar
Low and slow!
Re: d17a2 exhaust back pressure? cat delete...
If your going to buy a header and you do not want a cat then buy a race header. It is one piece and is designed for its very purpose. I have a race header on my ep3 with the a catback exhaust and gained bout 27 whp. It will be more than the gains that you would have cause I have a k series.
Old Jun 20, 2010
you might loose torque in lower rpm, not power
Old Jun 20, 2010
Gold Ghost's Avatar
Gold Ghost has a spectacular aura aboutGold Ghost has a spectacular aura about
im runnin a dc sports 4-2-1 race header and a dc sports cat back exhaust on my 01 civic ex. d17a2 engine. the header deletes the cat an makes the car sound raspy above 4k rpm. sounds nice down low though. yes u will lose tq down low but the gains in power up top r decent. my .02 is buy a decent header an down pipe an a good hi flow cat. i believe random tech is the popular cat on this forum. that combo plus a good quality cat back exhaust will give u a nice sound an a decent power gain. but dun expect much this car sucks for bolt on parts
Old Jul 17, 2010
gordonjj's Avatar
gordonjj is an unknown quantity at this point
my question is will i actually loose power due to not enough back pressure?...
I don't think there's going to be a gain on hp but neither are you going to loose.
Old Jul 17, 2010
the general idea with small displacement engines is you may lose some low end torque but gain high end hp with larger diameter pipes. you cant have both. if the pipe is bigger, exhaust gas will slow down. this is bad for low rpm driving, but great for hi rpm driving when a smaller pipe will not be able to flow as much air. the oem setup uses smaller piping to speed up exhaust so you get good all-around (but mostly low end) power, since the engineers prolly think most drivers will not be going above 4k rpms on a daily basis.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
jmdcivic
May 20, 2015 09:52 PM
Supramk3
May 11, 2015 07:55 PM
colombianDXcivic
Bolt-on Engine Performance
Nov 22, 2001 03:17 PM
