spring question
Old Jun 4, 2010
adamms's Avatar
adamms is an unknown quantity at this point
spring question
I just got my 2002 civic ex about a month ago, and finally was able to get it to pass inspection (needed tires and back seatbelts), when they went to do the alignment they stopped, and said I needed to raise the car up a little that the back tires were not sitting straight down like they should, so it would cause wear and tear on the tires a lot faster. Has anyone heard of that? The front sits a little lower than the back, about 4 inches off ground in front. I took one of the tires off one day to look at the springs and there just very short springs (previous owner was going to race it before getting rid of it) im not 100% sure if there coilovers but feeling that they are not, as on my saturn they looked way different. Does anyone have a good website I could see about ordering springs from Im usually not a fan of dealing with autozone and places like that. Thanks so much!
Old Jun 5, 2010
Re: spring question
maybe check ebay? its possible the previous owner put lowering springs on it, and you might also need new shocks. i think someone here is also selling oem honda springs for your car, check the FS forums.
Old Jun 5, 2010
speeeedddddfrea's Avatar
speeeedddddfrea is an unknown quantity at this point
Re: spring question
you should try looking at google shopping pages. there are lots of option there, just type what parts you need.
Old Jun 9, 2010
joenow's Avatar
joenow is an unknown quantity at this point
Re: spring question
hmm google shopping should be good. also try amazon once.
Old Jun 11, 2010
grendel's Avatar
grendel has a spectacular aura aboutgrendel has a spectacular aura about
Re: spring question
Pro Tip:
When you're shopping for your new springs, make sure they are 'progressive rate' - NOT 'linear'.
You can thank me later
Old Jun 13, 2010
adamms's Avatar
Re: spring question
thanks for replys, i ended up figuring out adjusting coilovers (didnt believe they were on there until i looked myself) have been having trouble though with the fronts, i can twist and twist the gold perch but it dosnt seem to raise it barely at all (did double check right=raise left=lower lol) not sure if the threads are stripped, whole reason is to fix back tires to align the car but tempted to buy camber kit so dont have to!
Old Jun 13, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: spring question
Probably stripped... I've heard of people having a lot of trouble after the coilovers are a couple years old. Buy yourself a camber kit
Old Aug 7, 2010
lordhelmet's Avatar
Re: spring question
Originally Posted by clyde dove
Probably C. It can't be A, as there would be no return pulse. It can't be B because the return pulse would be equal. It is probably therefore C, as if the spring attached was lighter, then it would continue the wave and there would be nothing reflected, which cuts out D. C is likely, as the heavier spring would absorb some of the pulse, but some would be reflected, giving the negative pulse.
Do what now?
Sep 26, 2023 06:44 PM
loosescrew84
16
Aug 11, 2015 07:08 PM
Curtchuk
Aug 5, 2015 02:14 PM
mHo2
Jul 27, 2015 12:57 PM
Ccoop87
Jul 9, 2015 03:26 PM
