Turbo leftovers, y8 manifold, d17a2, ingalls
First off, I'm open to best offers on most everything. I want it out of my garage. The civic is gone. Prices don't include shipping or paypal unless noted. I'm open to trades for miata parts, del sol or b16 parts. You can reach me faster through email as well... jarcrow (at) hotmail.com
1: Dezod intercooler. 2.25" outlets, sprayed flat black, really nice sleeper look. But I'll even sandblast it for you if you want to buy it. $150
2: d16y8 intake manifold. Bolts up to the d17 head. D17 throttle body bolts up, and there is the adapter for the throttle cables. But will require some form of bypass to EGR. Comes with the fuel rail and SRT-4 injectors that I used and the injector clips. The clips are all cracked/chipped/broken in some form or another, but work just fine and none are totally destroyed. $325 with injectors and rail.
SRT-4 injectors with functional but broken clips. $40
3: AEM 5 bar Map sensor. Used it for a month-ish. Works just fine, and in good condition. $60
4: Autometer ES series boost gauge. Never had a problem with it, just don't need it. Comes with a gauge cup. $30
5: Throttle body. Bought it as a spare to use for mock-up or if my TPS happened to die. No evap purge solenoid. $40
6: Ingalls torque damper and strut bar. I welded the strut bar bracket to the torque damper bracket so both could be used without the problems of not being able to thread the bolt far enough. Comes with all the hardware. $80
I've also got a d17a2 that is totally rebuilt. All parts are OEM honda. Every bearing has been plastigauged and all clearances checked accordingly. 75.5 mm OEM pistons. New water pump and oil pump and all new gaskets. $500 (There's more than that in parts alone and I've still got the invoices)
I've got tons more random crap lying around as well.
Intake manifold
Couple map sensors
Tie rods
Old hazy TYC headlights
Intake manifold
Couple map sensors
Tie rods
Re: Turbo leftovers, y8 manifold, d17a2, ingalls
Not entirely sure what you mean... the intake mani with the rail and injectors or what exactly?
Yes indeed it is, shoot me a pm
As for everything else... I really want this stuff out of my garage... offers are accepted.
bhollie
Aug 12, 2015 09:58 PM
Cross
Jan 31, 2002 06:36 PM
