has anyone installed 7" speakers on the door stock locations?
Old May 19, 2010
jmontoya21's Avatar
jmontoya21 is an unknown quantity at this point
as the title said,i'd like to know if someone did this before and what would the max depth be? any help would be greatly appreciated i got a 2001 sedan
Old May 20, 2010
95jellybean's Avatar
95jellybean is an unknown quantity at this point
Re: has anyone installed 7" speakers on the door stock locations?
7" speakers? 6.5" is the biggest to my knowledge unless you have 8"mid bass speakers. From my history as an installer, power windows or non? tougher with power. If you are puttin in good speakers your magnet depth will be big. Most civics come with a factory spacer but its not enough. You can make a thicker spacer yourself from high dens wood. Keep an eye on the glass when installing! I have seen it shatter.
Old May 20, 2010
electric130's Avatar
yes they exist. not very common, but they do. so do 6.75"
Old May 20, 2010
jmontoya21's Avatar
a lot high end component's now i see that they have 7" mids
Old May 22, 2010
instalher's Avatar
instalher is an unknown quantity at this point
yep even done a full 8 inch sub in the door keeping the stock front panel..my car is a 03 civic.. now after cutting out the metal the skin was pretty week so i placed a piece of 5/8 plywood cut out about 10 inches by 14 inches through the top of the door.(down the window track) then once it was where i cut out the metal, i just bolted it in with stainless screws... then dynamat extreme. and rock and roll.... but the door vibrated to beat all hell... just couldnt get the plastic to stop vibrating.. even layered the plastic door with a full treatment... so i had two layers on the inside of the door, two layers on the outside of the door and one layer on the plastic of the door... no use.... this sub was xover from 65 to250hz.
Old May 22, 2010
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
^^^nice, i always thought it would be to big as it took quite some effort to get my 6.5" in that tiny space. I suppose the depth of the magnet should also be taken into consideration.
Old Aug 17, 2010
instalher's Avatar
ya thats why i went with the earthquake sws 8s very very shallow and hit hard...
mistermenphis22
Apr 3, 2016 08:06 AM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
cheekyvirgin
Bluetooth
Apr 27, 2015 05:31 AM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
doublins
Nov 11, 2001 07:01 PM
