1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Civic wagon just died, cranks, but won't start?
Old Mar 29, 2010
chriswf's Avatar
chriswf is an unknown quantity at this point
Hey guys, I have a 91 Civic Station Wagon (wagovan).
FWD, 1.5 liter.
Last night, I took a right turn, and the car just shut off.
I tried starting it but it just turned and turned and turned. Didn't even catch much at all.
I opened the hood and tried jumping it, push starting it, no good.
I opened the distributor up, and it looked torched like this.
So I replaced everything there. Rotor, cap, etc.
Still doesn't start.
I took a wire out, and I noticed that there was no spark (old screwdriver trick).
So, what would keep it from sparking?
I currently also post on the civic wagon forums, as it's a little more specific to my model of car. I found lots of posts with "no starting" problem, and they all relate to the main relay.
Would the main relay keep it from sparking? IF it were bad?
Old Mar 31, 2010
Mecca8383's Avatar
Mecca8383 is an unknown quantity at this point
Re: Civic wagon just died, cranks, but won't start?
Try replacing the spark plug wires, Check the battery too..make sure it got enough battery water and is charged. While you're at it check the continuity of the main relay.
P.S: Did you throw that in the oven or something..it looks baked.
Old Apr 7, 2010
93civictx's Avatar
93civictx is an unknown quantity at this point
What happened to this problem? Did it get resolved? I have a similar issue.
Old Apr 11, 2010
oldskool89's Avatar
oldskool89 is an unknown quantity at this point
Like the other guy said check the main relay and all other fuses n relays, u never know that ur not sure about. At first I thought distributor but u already did that.
Old Apr 13, 2010
JDM_Ricer's Avatar
JDM_Ricer is an unknown quantity at this point
Try replacing the coil pack
Old Jun 17, 2010
Suntrana45's Avatar
Suntrana45 is an unknown quantity at this point
Replace the "igniter" located in the distributor, it used to be a extended warranty item, had a high failure rate. There is also a relay that can cause this, but have forgotten which one....article below may help.....good luck
http://earthrenewal.org/are_honda_au...safe_and_r.htm
Old Jun 26, 2010
picardii1's Avatar
picardii1 is an unknown quantity at this point
could the starting issue be caused by the pick up coil mine is doing the same thing and ive replaced both the coil pack and the ignition module or igniter as you guys call it and still get no sparck
bsmiley
Apr 27, 2015 01:27 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
