Strange starting problem
If I leave my car for 16 hours or whatever, more then 8 hours foresure my car wont start on the first try. Normally the second. I just bought a new battery since the other one was weak. After the car is warmed up I have no problems with it starting right away. The only thing I have done to it so far was change the plugs, I am at 70,000 miles. What should I check? This has only started recently happening. Im pretty good with maintenance, I just dont want to start replacing unnessesary things. It only happens when its the first time I start it that day.
thx
thx
Re: Strange starting problem
thx
thx
Have you tried leaving the key at II until you hear the fuel pump stop and then cranking the engine over ??
I have adapted this method on my 05 and everytime doing so it starts perfectly 1st crank.
Sometimes in the cold mornings I cycle it twice before attempting cranking.
Yes, letting the fuel pump fully cycle is also the trick when you are down below 1/4 tank. It takes a bit longer for the fuel pressure to build up in the rail. If you are still worried you can always do a fuel pressure test and see if it is correct and maintains correctly...if not, the fuel pressure regulator may be to blame. Let us know what you find.
black2k1vtec
Dec 6, 2001 09:49 PM
