civic idle flucuating?
Old Feb 1, 2010
dcneo's Avatar
dcneo is an unknown quantity at this point
[YOUTUBE]http://www.youtube.com/watch?v=Hh1ZcGJsqDM[/YOUTUBE]
my cars idle keeps going down while i hold on the gas pedal? what could it be?...see video.. ive replaved the iacv and tps and got a new intake like a week ago but still have the problem.
this makes it so i cant drive really
Old Feb 1, 2010
RonJ's Avatar
RonJ will become famous soon enough
Re: civic idle flucuating?
Your (check engine light) CEL is on. Pull the codes as described here. Post the codes that you retrieve.
Did you calibrate the TPS after you installed it?
Dis you reconnect all of the vacuum hoses and bleed that cooling system after replacing the IACV?
Old Feb 1, 2010
dcneo's Avatar
the code that keeps coming up is for tps which is already replaced and calibrated and p0505 Idle Control System Malfunction. no i havent tryed bleeeding the lines i didnt think that would be it but its worth a try how do i bleed them?
Old Feb 1, 2010
RonJ's Avatar
The TPS code may be causing code P0505. Have you checked voltage to and from the TPS at closed and wide open throttle?
Air in the cooling system can cause a hunting idle, as can a disconnected vacuum hose or an intake air leak from the TB or IM gasket.
P0505 can also be thrown by a bad ECT sensor (2-wire plug under the distributor), so check that as well.
Old Feb 1, 2010
dcneo's Avatar
tps voltage is good... air bubbles not the problem..... could it be spark plug wires?
mikemc422
Aug 9, 2018 05:41 PM
beneditti
Jan 15, 2016 12:31 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
vtechcivic
Apr 21, 2015 06:58 PM
streetglower123
Apr 12, 2015 10:56 AM
