1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Coolant leak
Old Feb 1, 2010
dacubs's Avatar
dacubs is an unknown quantity at this point
Cool Coolant leak
I have a 94 civic 1.5L and coolant is has puddled on ground after turning car off. The heat is on by the way. What should I look for Any ideas! It's my daughter's car, but I get to fix it! Thanks for any help.
Old Feb 1, 2010
TRIZ's Avatar
Re: Coolant leak
Your positive its coolant (green) and not just water from having the ac/defroster on?
Old Feb 1, 2010
dacubs's Avatar
Re: Coolant leak
Positive, refilled radiator and out it went again after turning car off and it just keeps leaking. Not sure where from, its dripping off the oil pan.
Old Feb 1, 2010
dacubs's Avatar
Re: Coolant leak
It ran ruff after a few minutes and then I turned it off. I can't tell if it's coming from the water pump, but it looks like the water got hot and melted a new cv boot I put in, damn.
Old Feb 1, 2010
RonJ's Avatar
RonJ will become famous soon enough
Re: Coolant leak
If coolant is dripping from the weep hole at the bottom of the lower timing belt cover on the LEFT side of the oil pan, then the water pump almost surely must be replaced.
Old Feb 1, 2010
TRIZ's Avatar
Re: Coolant leak
Could be the headgasket if its dripping all the way down to the oilpan...
Truth is, you gotta poke your head around with a flashlight or shoplight and figure out where its coming from exactly and then we can tell you how to fix it.
Old Feb 1, 2010
RonJ's Avatar
Re: Coolant leak
I corrected my previous post as I should have said LEFT side of the oil pan for a leaking water pump.
An external coolant leak from the head gasket is rare though not impossible. In addition, a blown head gasket would often be accompanied by other problems. A coolant leak from the water pump is more common, but as Triz says, try to precisely locate the source of the leak.
cukaracha
30
Jul 26, 2015 12:01 PM
Bounddyy
Jul 8, 2015 11:22 AM
ZILLA
Jul 5, 2015 05:24 PM
Causemo
Jul 5, 2015 06:42 AM
Causemo
Jul 4, 2015 07:11 AM
