Oil disappearing! Where's it going?! Mystery...
Old Dec 15, 2009
jamiesalisbury's Avatar
jamiesalisbury is an unknown quantity at this point
Unhappy Oil disappearing! Where's it going?! Mystery...
Hi all,
I'd really appreciate some help with this problem.
I have a '99 Honda Civic, which loses oil quick - the oil light currently comes on roughly once a week. I have put cardboard underneath the engine for several nights and there is not one spot of oil on it. There is also no black smoke that I have seen coming out.
My mechanic has had a good look twice now, but can't find any oil leaks or any other problems and is mystified. It's had a service and seems to be running ok.
Obviously, my next course is take it to another mechanic, but before I do that has anyone got any ideas??? I could just be throwing money away.
I'm not very good with cars, so any technical terms may need to be explained, sorry! I'm really looking for ideas I can suggest to my mechanic.
Any help would be massively appreciated!
Thanks in advance
Jamie
Old Dec 15, 2009
Re: Oil disappearing! Where's it going?! Mystery...
sounds like expensive engine work. if its not leaking out from seals, its prolly being burned and that means new piston rings and valve guides (motor rebuild). if the oil light is coming on, you already have serious damage done and it will only get worse due to low oil pressure. maybe the oil pump is crapping out.
Old Dec 15, 2009
CivicAK's Avatar
CivicAK is an unknown quantity at this point
ya man if you have BLUEsmoke coming out your burning oil, not black.
Old Dec 16, 2009
There's no smoke at all that I can see, apart from a little white smoke in the first couple of minutes of running.
Thanks for the help, sounds like bad news. Any other opinions?
Old Dec 16, 2009
birdman23's Avatar
birdman23 is an unknown quantity at this point
hi im new here however if you are not getting any smoke than you probably should check your pcv valve mine did the same thing except it cost me an engine
Old Dec 16, 2009
birdman23's Avatar
ck your pcv happened to me
Old Dec 16, 2009
white smoke means coolant burning too. maybe blown headgasket.
Old Dec 16, 2009
CivicAK's Avatar
But wouldnt that mean its always burning white? unless it's a weeping leaking???
why could it be the pcv valve, and how could it destory the engine?
Old Dec 16, 2009
if its a small leak, after the engine warms up and burn the coolant, it will run fine without smoke.
pcv valve is very important to vent corrosive gases out of the motor. if its clogged, over time it can kill the engine, or at least make it run like crap.
Old Dec 22, 2009
bnikanor's Avatar
bnikanor is an unknown quantity at this point
probably you burned your oil along with the combustion.
i have experienced this with another car (a toyota), and have to replace the piston rings. your engine needs an over haul man!
emich
Dec 11, 2015 12:20 PM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
15EXCoupe
Jul 30, 2015 12:59 PM
muttleytm
Jul 11, 2015 06:00 PM
