Check transmission fluid level
Old Nov 30, 2009
hunch1784's Avatar
hunch1784 is an unknown quantity at this point
I am the new owner of a 94 honda civic lx with 1.5L engine and 5 speed manual transmission. How do I check the level of my transmission fluid, and where do I add fluid? There is no dipstick to check if I need to add fluid and I think I may need to because it looks like I might have a small leak around the pan.
Old Nov 30, 2009
Re: Check transmission fluid level
i dont have a manual, but theres supposed to be a finger hole of some sort to check the fluid level. dont know where to add new fluid tho. maybe the manual guys will chime in
Old Dec 1, 2009
Silver02EX's Avatar
Silver02EX is an unknown quantity at this point
I could be wrong but i don't think there's a pan with an manual tranny. To check the level there should be a drain bolt and a fill bolt above it. Undo the fill bolt and put your finger in there to check the level, if you don't don't feel any fluid, add more. a funnel and long tube works well.
Old Dec 1, 2009
BlueEM2's Avatar
Whachya lookin at?
That sounds about right to me... it's a bit of work though, just to check the fluid... if you are already there you may as well pull the drain bolt and put new fluid in.
Old Jan 1, 2010
terrible2's Avatar
terrible2 is an unknown quantity at this point
what about for an auto tranny, how do I check the oil on that?
Old Jan 1, 2010
Foffie's Avatar
Im a Senior Member. Take that Noobs!!
Foffie has a spectacular aura aboutFoffie has a spectacular aura about
use the dipstick located on the front orback of the trans depending on your car and check it while the car is off
Old Jan 1, 2010
laack's Avatar
laack is an unknown quantity at this point
manual transmission isnt too difficult if you have the right tools.. if you are on the passenger side of the car, look straight down on the side of the transmission below the batter box area. there is a bolt (17mm) i think, running parallel to the ground. use a torque wrench with a long handle of you have one, it will make it much easier on your knuckles. with the bolt out, put your finger just inside the hole, you should feel fluid. if not, its too low refil though this hole until fluid dribbles out. drain plug is directly below that bolt. it has a 3/8 drive square head to it. somewhat of a hard angle to get in there. no pan or filter. I'm sure someone has said it already, but use genuine honda transmission fluid only.
Old Jan 1, 2010
auto trans fluid you always check when the car is hot and running, altho if youre fast you can quickly shut off the motor and then check it within 30 seconds. after that, you will not get an accurate reading.
Old Jan 1, 2010
terrible2's Avatar
Well ive checked all my dipsticks but I dont think any has led to the transmission = \ ill look more carefully
Old Jan 1, 2010
its towards the back and left when looking at the engine bay from the front. if you have the stock intake, you prolly wont be able to see it, but its underneath the resonator box.
mattdoc
Mar 14, 2017 12:10 PM
cruisers10
May 12, 2015 10:46 PM
bsmiley
Apr 27, 2015 01:27 PM
HX
Dec 28, 2001 10:04 AM
GoofyLogicInc
Oct 25, 2001 09:50 PM
